probably not real c/b dude....
real c/f is like $1200+
I have never seen a fake carbon fibre bonnet as there is no plant i know of capable of dipping such a large object nor would it be of any financial gain to do so.
I think you mean or what you should mean is this.
Carbon fibre bonnets purchased under $1000 are usually fibre glass based with the top layer being carbon fibre.
You get the look but not the structural advantages that you do with a complete carbon bonnet.
This is much cheaper and what most cheap Carbon Fibre bonnet makers do.
It is still "real" carbon fibre.
totally different car here but the last quote I had for a real on e was excess of 2.5k full CF.
Eastbear, Stout, Jun full carbon fibre bonnets are around $850-1300 plus delivery from Japan.
Its just unfortunate that delivery costs so much :P
Also when a full carbon bonnet has been made within Australia and has been crash tested this will see a large increase in price.
Its just unfortunate that delivery costs so much :glare:
Been done Aaron, Custom Carbon has bonnets last I knew with ADR Stamp for approval if I remember correct
CUSTOMCARBON.COM.AU
CUSTOMCARBON.COM.AU
yep and thats who quoted me on the one for my 2006 holden combo..
Just out of interest I got pulled over today and fined for not having a mod plate for the pod and micrrotech ecu $75 no points BUT he made no mention at all about my carbon over fibreglass bonnet but then again I didnt ask either lol
WOW Terry your pod is secured... Yeah...
How did they get you on the ECU??? How did they even know???
Pod is secure, I have a handset for the microtech and he knew what it was, to be clear on this it wasnt a defect, it says on the fine "drive vehicle if equipment does not comply with the vehicle standards" (word for word there) offense details "pod airfilter, aftermarket computer" I'm not too concerned but the gist of it was, I didnt have a mod plate for anything and he wants me to get one to comply with the law, he could of defected the car but let me off with this as a warning. I have a feeling he just wanted to look at the car and then started telling me about his RX3 with a microtech and all the shit he went through with it even tho he is a cop lol. The reason he pulled me over was, I was be tailed by this total f**kwit who was tailgaiting me for ages and when I got to an intersection, I blasted through it to leave him behind, he was somewhere close and heard the roar and blow off.
i knew that mr-toy i just made the post cause ive seen a few ppl around wanting c/f bonnets cheap...i thought that was cheap
2 yrs ago mine cost me $800 in Hong Kong, it cost $3-400 to import.
why bother paying that much for something that you can only use on the track but i dont have a car so thats just my opinion
My bonnet had a acid rain look to it and a good respray was quoted at $750, this way I get a spare bonnet and no respray hassles, straight up bolt on all I had to do was switch the water spray nozzles.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
