  • Replies 255
I'll be at the show, on foot at the least. Any point in bringing a plain-jane R33 GTST? I dunno that it's 'show' material compared to what I know is out there :laugh:
bring it along... mines pretty stock aswell...should be a fun day
Mmm, just remembered I have some big embarrassing gashes in my front bumper from a few weeks ago due to some anonymous carkpark hero (b45t4rd...). I don't wanna show her off lookin' like that - I'll wait til it's fixed. But I'll be at the show for sure.
Ok just fixed my front bar so I'm in. ;)
I'll actually enter this time not just drive in and park next to skylines like at marqees in the park.
SL33KY
Terminal
Baconer
Frink
Donnan
Kabala (now known as S T A R 3 3)
Supadan
Leech
a20089
1JRocket
Rumble
loymclure
CeJay
ib6ub9
Dereck (Fifth Gear Motorsports
zooee (Robert)
r33skyflyin
GT-PASSAGE
TeeJay
Are all the lines meeting up first ? or just at the event ?
I My cousin said if he's down from Sydney, he'll be more than happy to join in the festivities with his V35. But that'sif his wife doesn't ruin the trip and cancel it.. she's bossy.. but she's hot. So it compensates. ;)
Tell her to come along too;more eye candy for the single SAU'ers! LOL!!
Have we actually been allocated a spot, if you look on here http://www.actmotorclubs.org.au/go/shannons-wheels-expo
we appear to be bundled in number 39? unless I'm wrong, anyone know any different?
sorry guys, but im out for this little outing now....
SL33KY
Terminal
Baconer
Donnan
Supadan
Leech
a20089
1JRocket
Rumble
loymclure
CeJay
ib6ub9
zooee (Robert)
r33skyflyin
GT-PASSAGE
TeeJay
the other day my heater core decided to spring a leak on my way to work which, because of the hot coolant, fogged up my windscreen instantly. so i had to pull off the road onto the medium strip not being able to see a damn thing and as a result of being "blind", i drove over a small stump and tore a sizeable hole in my left side skirt... :) i wont be able to have it fixed in time, but i'll try and come have a look....
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
