actually I wouldn't mind finding my fence lines, and key levels :thumbsup:
Can't imagine it would be fun to do a 1300spm sloping block though.
eep upwey! last job i did there it nearly drove me insane! took 2 day and the block had a height different from top to bottom of about 16 meters on a kinda standard 800spm block :S might be a bit much for a weekend job lol
  • Replies 362
Hehe, did say it wouldn't be fun :( It's only about 20m rise over 60m length :thumbsup: Need to figure where and how big my garage can be :D
im a network engineer and Rigger. :action-smiley-069:
Intersting combination!
I work at cadbury :P
On the upside i get cheap chocolate and a good pay rate. Worst job in the world though
I was a network engineer/PM at Cadbury for aboput 5 years. I wonder if the crew is still the same out at Ringwood/St Kilda.
That happens at Schweppes in Tullamarine. The company I work for is contracted to do a bit of electrical work there.
It's funny though, all depends which security guard you get at the gate. Some just glance in the back of the van, while others will want to see inside your toolbox :(
They always used to do it at Ringwood too :rofl: We had em sorted though ;)
Health, Safety and Environmental Consultant :action-smiley-069:.
At the moment i'm working almost exclusively with hazardous materials.. in particular Asbestos. If you have any questions about hazardous materials (particularly at your work place) fire me a PM :P. Love my job. Before this job I was running the Parkdale Bottleshop.
Health, Safety and Environmental Consultant :D .
At the moment i'm working almost exclusively with hazardous materials.. in particular Asbestos. If you have any questions about hazardous materials (particularly at your work place) fire me a PM ;) . Love my job. Before this job I was running the Parkdale Bottleshop.
what happens if i grind up asbestos and snort it thru a pink straw.
You will be fine until about 20 years later when you will 5-10% more likely to develop cancer and in particular Mesothelioma or cancer of the lining of the lung which is at this stage completely incurable and see you essentially drown to death in your own lung juice in a year or two. Alternatively you will be fine. So ya.. about the same as if you smoked a few cigarettes really :thumbsup:.
My occupation is packer at Coles, yes it's a rubbish job but it pays.
Would love to work more hours than what I'm currently working.
There are some interesting jobs out there.
Asbestos is harmless if swallowed. It is only the respiratory system which is affected.
And yes Asbestos could be substituted for smoking, i'm not sure it would provide quite the same feeling though :P but the hazard is about the same!
i see. because my school, Lakeside Secondary College in the northern suburbs is full of the shit. its kinda scarey
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
