After having fixed a dry solder joint in my AFM tonight(Most likely from the heat I'm about to talk about) I noted that the engine bay gets damn hot and stays hot for a long time (Series II R33 GTR). With this in mind I'm wondering if anyone has endevoured to vent the bonnet or purchase a vented bonnet with the aim of reducing engine bay temps and hopefully prolong component life. I'm not looking for huge rice vents, just options on something practical.
What are peopls thoughts on this idea, do you run the risk of allowing rain/debris/dust/dirt etc into the engine bay in larger than normal amounts, is there a real temp drop as a result, what have people done if they've pursued this idea (pics would be great too).
Thanks all
https://www.sau.com.au/forums/topic/151325-bonnet-venting/
  • Replies 68
I had a Carbon fibre vented bonnet and that kep my temps down and also had a inlet over hte air filter. When i went to a standard bonnet i felt the car was not as responsive prob due to no air intake vent. i aslo found on hot days the temp needle ran higher. I have no issues whit dirt or water.
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816241
I was think bout getting a vented bonnet but i was wondering about driving it in the rain, say if u stop at the traffic lights or something where the engine is gonna be hot does the rain running down through the vents directly onto the engine cause steam or anything?
I also know your no ment to directly cool a hot engine incase some cracks goin from hot to cold that quickly
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816490
look up the 270R 200sx tuned by nismo
have a look at what they did it would be hard to spot if yor painted the whole lot in the factory colour
the hole I cut is very small and only just behind the radiator shroud and stops just before the rocker cover
hmmm maybe dont have a look lol
just refreshed my memory and its not how I remember it
my advice cut hole in bonnet not frame no one likes a floppy bonnet
fill hole with mesh paint mesh black tada
function without the wank
Edited by 1400r
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816516
Well what some people do is place a number of washers where the hinge bolts on effectively lifting up the rear of the bonnet letting air escape out the back. You may also need longer bolts.
You could do this before a track event and then put it back to stock afterwards.
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816771
Mmm. I think that would look a bit wierd personally, someone got some pics?
Yes it looks weird. Heat isnt a problem on the street when you're talking a turbocharged engine of course theyre going to get hot. It's good to keep things cool yes but the engine bay has been designed with a higher temp in mind from the factory.
On the track where you're seeing a great deal higher temps is when you need to worry about it and think about getting temps down or moving air around or keeping heat inside the exhaust etc.
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816794
Thanks all
hey mate, i recently got a z tune vent moulded into my 32gtr bonnet i noticed around 15+ degree drop in engine temp.
and rain gets in. but i dont really notice it bieng dirty or anything. just made sure the seal around my cam covers and coils is in good form!
just adding to the thread after reading the rest of it.. i have been pulled over by police on a number of occasions and nothing ever mentioned about the bonnet, or headlight.. or anything for that matter.
Edited by Angus Smart
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816925
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
