  • Replies 46
Hmm , so looks like R32GTST's get the 15/16 bore master cylinder .
Some more possibilities , these Nissans have 25.4mm (1") master cylinders .
Maxima 5/90 on 3L , Pathfinder D21 VG30E 4x4 10/92 - 11/95 , Pathfinder R50 V6 4x4 11/95-00 .
Patrol Y60 (GQ series) had both the 1" and 1 1/16 BMC .
Going to have to look through wreckers or pester some poor parts person .
Cheers A .
I had a dig through Pick and Pay Less today and mainly found out what doesn't have what I need . Just about all the larger heavier cars like 280ZX's , Z31 300Z , 300C's use some form of BM44 15/16 bore master cylinders .
The only useful thing I did find was a D21 Navara (5/87) with a Nabco BM50 1" cylinder , perfect except it had no proportioning valve . It also only had 1 front and 1 rear hydraulic line outlet so would need a "T" for the front and some kind of external rear line pressure limiting valve ie like JDM R30's and Bluebirds had .
They had no Y60 (GQ) Patrols or later D50 Pathfinders to look at .
Cheers A .
Interesting....this means you have a good chance finding something local. PBR make local master cylinders for early D21s. Not sure where the lines come out though?
The kindest thing anyone ever did to an Australian built Nissan was to throw all PBR/Girlock hydraulics as far away as possible . Irks me to say it but local content brake components are rubish compared to JDM bits .
Rally fraternity hate PBR/Girlock cylinders because they are built to a price not to a standard .
Thanks anyway cheers A .
  • 1 month later...
discopotato03, I'd like to wade in on this discussion. I'm currently looking for a solution for my S13 Silvia I'm building that now has a set of R33 GT-R Brembo's fitted:
Pics
http://www.sillbeer.com/2007/01/and-now-wh...ew-hotness.html
Now I also saw the article on the US site where they had used a Z32 300ZX Brembo brake upgrade and went for the 1 1/16" non-ABS BMC. Unfortunately like you I've realised they're only in LHD guise (UGH!!!!).
So if anyone can help in identifying if Nissan (ie. Nabco/Tokico) make a 1 1/16" non-ABS BMC for RHD situations from a car with a similar weight distribution as a Skyline/Silvia, please speak up...otherwise a 1" might have to do. Part numbers would be very helpful too.
Cheers
Brendan
Just a thought, but according to most specifications around the web, the R32 GT-R N1 versions had the ABS removed to reduce weight, would that then point towards the possibility of them having a 3 port brake master cylinder in the larger BM57 size?
Anyone?
Edited by VSPEC32
Dayam aye, why is the R33 one smaller? You'd think less travel, more force would be better (except when you lock them up too easily)
Just remember to think about the correct meaning of the words you are using....and never forget these two equations.
Pressure (P) = Force (F) / Area (A) .................... Eqn (1)
Friction = uN (Normal force N) .................... Eqn (2)
A few things impact on the general setup...but we can neglect pedal ratio as we are using all this different gear on the same car (Assumed).
So you put a smaller master cylinder in your car. That means you have less area of piston. So making the denominator smaller does not affect the numerator. So that is using a smaller master cylinder doesnt directly affect the force...it affects the pressure. It increases the pressure in the brake lines.
Now that is related to the caliper and pistons/pads as its the pressure in the brake lines that apply a normal force to the pad onto the rotor.
So there are two types of friction, static and kinetec. Now whilst static friciton is higher then kinetic, we dont want to be locking brakes. As that means we have less grip with the road as a locked tyre is modelled as kinetic friction. (remember thats the lower of friction values...bad if we are tryign to stop a car) So remember a rolling tyres grip level is modelled by static friction, ie no relative slip between the two surfaces.
So not wanting to lock a tyre, we must ensure the pad is moving relative to the rotor. ie Kinetic friction.
Now we only want enough force that brings the pad and rotors to the brink of lock up. If we lock up we lose tyre grip with the road.
So remembering that P = F/A. You havent changed your calipers, so the Area of pitons is the same. Having increase the pressure in the lines means that F=PA. A is constant, so the more pressure we have the more force we have.
So that all said, this all assumes the same pedal effort all the way back at Eqn 1. So you apply a 10kg load onto the brake pedal with a smaller master cylinder you will be closer to locking up the brakes with a smaller master cylinder then you would a larger master cylinder. If you have bigger pistons in your caliper and combine that with a smaller master cylinder then you will again have brakes that lock up too easily.
So if you increase the piston size in your calipers, then its not a bad idea to increase the diameter in your BMC. It helps not to have a hair trigger brake pad ready to lock your rotor as soon as you look at the brake pedal. Looking at Nissan it seems they have done the same thing.
Now take this with a grain of salt, but i have driven an R32 GTSt with Brembos it stopped realy nicely. Loved how it stopped. I have driven an R33 GTSt with Brembos and i jumped on the pedal and instantly locked them all up and crashed into witches hats. Now i dont know what pads and tyres were like, and the R33 was on a slippery skid pan...but its something that is in the back of my mind.
So why did Nissan drop the BMC size on the R33. I dont know. But if ppl can tell me the coeffecient of friciton of the R32 and R33 std pads...i suspect they dropped the BMC size as they reduced the friction in the pad used as the car had bigger rotors and would handle the heat better then an R32. Lower temp pads normally means lower friction coeffecient.
The GTRs which would have had more performance orientated pads woudl have had a higher u level meaning that a pedal offering more modulation / travel would be desirable.
Has anyone got any solid information on this?
Our Targa car is a genuine R33 N1, it has ABS. I'm pretty sure i've heard duncan taling about the R32 N1 ATTESSA unit, as it's ABS functions are deleted, so R32 N1 (and Nismo) have no ABS.
Better late than never.
Late 1992 R32 GTST Non-ABS Master Cyl.
Excellent pedal feel. Almost too easy to lock all 4 wheels but that comes down to the pad that I run.
Hasn't had a flush for 1yr. :S
Only markings I can see on it are:
BM-44
NAB00
I had a mate with a Late 1992 GTS4 check his he said it says..
Japan Nissan Tokico BM50
Just had a look at mine
car was originally an 1993 R32 GTS and it has a Tokico BM38.
pedal feel is good with the crappy single piston callipers but i am going to have to upgrade it now that gtr32 calipers and 324mm rotors are going on or I am guessing the pedal would hit the floor before lockup :glare:
OK, still trying to track down information on the brake master cylinder from an R32 GT-R N1 (BNR32 N1) - I did manage to find a Chassis number...would that help anyone in tracking it down?
R32 GT-R V-SPEC N1 > KBNR32RBFS ZN
R32 GT-R V-SPEC II N1 > KBNR32RBFS8 ZN
Cheers
Brendan
Edited by VSPEC32
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
