yeah need to know when every one is leaving
I'll be going the back way - Lillydale, Yarra Glen, Yea, Seymore, Shep.
Will be in Lillydale at BP on the way out at 7pm - Leave at 7:30 if anyone want to meet there let me know.
But their will be a main cruise thread posted for the hume friday night and sat morning.
  • Replies 204
Posted Images
I'm heading up early, I had a client hold back so work for me so I could leave work early to go up and see him ;)
YAY for good clients ;)
So I'll be headding to shep around 2-3 on friday arvo
Please see this thread regarding Volunteers for Saturday: - http://www.skylinesaustralia.com/forums/in...howtopic=155052
Priorit entry to DECA R2.
Please see this thread regarding convoy's to Shepparton: - http://www.skylinesaustralia.com/forums/in...howtopic=155034
The event schedule should be released tomorrow.
Watch this space...
Grrr and I was waiting for them today :thumbsup:
You release the regos while I'm up bush at a job ste now you release the layout while I'm in QLD :O
You SAU guys are out to get the WRX guys after a first time novice won from our club at the last event :happy:
Actually ignore that - I just did a search and it seems the old Feb event schedule has gone to internet heaven.
Along with all the video's from Feb as well!
But for those that were there - it was the one with THE STORM. Skidpan events from that one will be the same as this one.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
