Ok, before i get flamed ive done a search and i couldn't find a conclusive thread about this.
This is basically a question/info thread
Question: i want to get an ECU for my car (r33 rb25DET), and wanna know the main differences and adv/disadv about each one.
So far I've worked out that:
- Apexi FC is the easiest to tune, u can achieve a better tune, its relatively cheap ($1200) its got a hand controller, good resale value and very reliable. Bad points are it uses AFM and does not have a boost controller
- microtech is better for racing but not good for street since it is harder to tune for part throttle and to tune for economy. Alot of tuners are also not competant using it which means more dyno time is needed (= more $$$). Not sure how much the unit costs but it is slightly more expensive than AFC i think. Good thing about this one is that is uses a map sensor instead of an AFM, so no need to upgrade to z32 AFM.
-wolf3D, is the 1 i dont really know anything about. Apparently its good tho.
-Greddy emanage, apparently is more a A/f controller mush like the apexi SAFC, altho its got more features than a SAFC. Compared to an AFC, i'm not sure which ones better. E-manage can be obtained for under $400 from nengun.
- remap, is a ok option if u plan to do no more mods on ur car. If u do, expect to pay 600-700 for each retune (which is only slightly more than a dyno run) but more importantly u are locked into the 1 tuner. Gains are also not as good. Dr-drift chargers less than 1000 from memory for the 1st remap.
So far this is what ive understood. My car is a street car with very little track time and a stock turbo/afm/injectors. Im on a budget of (max $2000 drive away) and would like to hear pples opinions/experienced to help me decide which way to go.
https://www.sau.com.au/forums/topic/151907-ecu-for-r33-rb25det/
EMS
http://www.skylinesaustralia.com/forums/in...;hl=Which++ecu*
PowerFC or Microtech
Microtech or Link
http://www.skylinesaustralia.com/forums/in...=128762&hl=
There are a dozen other threads, each asking for peoples personal experience... yadda yadda yadda. Im sure you get the idea.
End of the day its a case of choose the ECU your tuner feels most comfortable/familiar with using.
Your ECU/Tune/Car performance will only ever be as good as the tuner, decide on a workshop/tuner and go from there.
Thats the common denominator you have grossly overlooked
that's so true, I dunno how many people I have spoken to who have complained about the tuning job such'n'such workshop did but it was like the first time they had even dealt with that ECU.
I was speaking to the guys at UAS the other day about the PowerFC and if there was going to be anything to replace it from Apexi and they said they didn't have any info, but were going to start working with the E-Manage 2 in the not too distant future and said depending on the ease of tuning (and how long it takes the tuner to get it down-pat) it shoudl perform just as well if not better than the PowerFC.
the powerfc has a boost control kit, its on www.nengun.com
using an afm is a good thing, using a map sensor is not
the emanage is a piggyback and always will be, so i dont see how it would be better than a replacement stand alone
im in a similar boat at the moment and i agree, the information out there is not conclusive... it isn't that easy to find PFC's and your still up for $600 a tune... as long as you dont want much more than 220rwkw, its probably not necissary either. Here are the obvious options as far as piggy back ECU's go - can anyone provide info as to tuning costs for these and any other information ive missed or am unsure about:
Apexi SAFC 2
$320 delivered (2nd hand)
+ 2 saved maps (cruise / performance)
+ Knock sensor
- 12* 2map
Apexi SAFC Neo
$430 delivered (new)
+ brand new interface
. 16*2 map
- no knock sensor
- no saved maps
Greddy Emanage Blue:
$516.51 delivered with harness
+ 16*16 map
+ Ignition Control
+ injector control
- no saved maps/profiles (???)
- apparently the timing adjustment is not great
- has issues with heating up coils (???)
Greddy Emanage Ultimate:
$722.91 delivered with harness
+ ignition control
+ injector control
+ 2 saved maps with quick flick switch to swap between.
+ auto tune (not a huge help, but worth mentioning)
+ extra inputs for mapping of many other car functions
- not a replacement ecu
Apexi Power FC (included for reference)
~$1200 with hand controller (2nd hand)
+ complete ECU replacement
+ complete control over engine
- Difficult to source these days
- $600 to tune.
2nd hand PFCs are like $800 via slidewize imports
he is a trader on the forums, speak to him
he should be able to get rb25 as well
tune should be $500 ish
or more like $400, shop around, plently of PFC tuners
theres no need to emphasise on multiple maps, you just tune the ecu the best and safest settings your car / engine can deal with. theres no need for a normal spec tune and a "race" spec tune. just tune with whats safe and be done with it. fuel economy will come from how you drive it and your foot on the pedal
im looking into all these options at the moment, i know info bout pfc but Emanage n that i cant find info on or opinions really.. what i cant find out is if emanage can run bigger turbos n that? its prob under my nose on this site but havnt come across it yet
ASK YOUR TUNER
a good indication of how good an ecu is the number of people who use it and documentation etc out there. if you cant find much on the emanage, chances are not many people use it. look at the pfc faq (in my sig) should give you an indication on the number of people that use the powerfc, and for good reasons too.
lots of documentation on the motec, for good reasons too
etc, if its good people will have documentation, howto's, guides etc
i dont think PFC's for the rb25's are as easy to come by as you think... which is why im considering these other options, especially since im only after 200rwkw... will pm slidewize though and see if he can help tho.
aside from getting a PFC, are there any other comments/feeback/info about the piggy backs i listed ??
last time i spoke with zac about the PFC availability he said it was fine and no problems with finding them, best to ask him. a 200rwkw well tuned r33 with PFC will run very nicely and have some good average power. the response and engine pickup is also much better as you are to tune the low load ign areas significantly. im about 12deg more advanced timing below 3 grand, so the car feels amazing to drive.
powerfc & alsd works fine, its just an official wiring change to make it work, its under the tutorial section, search for "active-lsd" in their and you will find it, its also in the PFC Faq
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
