Well after much thought im going to be selling my GTST and getting a 32 GTR... which i was going to do originally but then went off the whole idea and thought i would just mod up my GTST. Changed my mind again :P
So im deciding whether i should sell the parts i have sitting in my room and sell the car as is or put them on the car and then sell it.
I reckon i sell the bits that are there and sell as is for about 14k... what ya reckon?
Parts sitting in my room:
-Genuine GTR Alloy Guards
-Glass GTR front bar (unpainted)
-Plastic Genuine GTR Sideskirts
-GTST rear spoiler
-Genuine GTR FMIC
-Pineapples
Have to do a few things to the car first as there are a few minor things that need fixing... once thats done its up for sale and i buy a shitbox commo or something til the GTR lands :(
https://www.sau.com.au/forums/topic/15220-looks-like-its-the-32-gtr/
  • Replies 60
yeah i spose... could use the money to put towards the car or buying a shitter in the meantime.
will have to wait a few months or so tho... til the car is ready for sell.
might advertise the parts now...
I think parts for R32 are a lot harder to find, hence the demand.
Are you going to be able to import an R32 GTR or just look around locally, or still the japan idea?
If i sell my car next year.. i've pretty much come to the same conclusion. Strip the parts off separate and sell them to whoever needs a cooler, EBC, etc. If u have plenty of time available to sell it, sell all the addons separate, and just sell the stock car...
Then some p-plater can buy it and not kill themselves, or choose to stick all the go-fast bits on themselves over time.
yeah thats what im doing... and ur right the 32 bits are hard to come buy... mainly cause the 32 is less common i would say. the suspension i will leave in it as well as the ECU even tho someone wanted to buy that from me as well seperately lol
almost everythings gone now apart from the guards and the FMIC.
haha.. doesn't everybody?
Soon we'll all be owning GTR's in one way or another.. R32 GTR is going to become pretty common.. I reckon if you can pick one up for low 30's it is a bargain... won't devalue.
Actually stuff it.. i'm adding R32 GTR to my list of "3 possibles" for next year :D
narkeh's raping his car for parts... good 2 see... i'm keepin my car in da family hehe (my old man's takin the GTS)... we'll achieve the same thing tho.. R32 GTR's ahoy... jus dun bid for the same car I do lol.
I've been looking a bit around the net.. early 89 models will be going for like $15-$20k next year ! if you want a bit of an older one, sounding pretty good.. Even if u need to budget $10k for an engine rebuild and a spray job sounding pretty good to me..even if u have to wait until 1 Jan 2004 to get it...Some places are allowing you to buy them from auction and keep them in storage
look at this one for a bargain..
http://www.prestigemotorsport.com.au/au/st...asp?StockID=730
or
http://www.prestigemotorsport.com.au/au/st...asp?StockID=733
Hmmm... i'm thinking 11sec daily driver :O
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
