turns out one of the braided lines split on the starter motor so oil pissed all over it, then caught fire and melted through clutch line and that kept going lol.. from what we can tell engine is fine, just gotta fix burnt wiring and replace what ever hoses/lines need replacing . hopefully done before domain HC!
Give me a yell if you need anything cobber, my old engine is still 99% complete so can rob it for spares :woot:
spotted: BOOST31 GTR being reborn, what a weekend
IT'S ALIVE!!! haha. thanks for the help buddy :woot:
now spotted is pretty much a whole other GTR in parts in my shed, better get snapping and start a for sale thread
spotted me having a bit of a shit fight with my turbo
i now have a new manifold-turbo gasket, 3 inch dump pipe and none of the rest of the exhaust :worship:
sounds awesome but i'll attach the rest of exhaust tmrw
can't wait to drive it with the new dump :)
the black r32 gtr with autocraft stickers is Jamie's, white one is P.J's, hes on the forum here somewhere :worship: not sure about other ones. burgz was in one doing limiter launches lol.
gotta love a limiter launch!!!!! also gotta love having a complete spare drive train in the workshop.....
Mine was the Grey 1 with white wheel's...
Wishing i had have spotted someone breaking into my 32 on sunday and stealing all the audio gear :starwars: luckily they couldn't quite get the car but snipped a few cables under the bonnet and played with the fuses! Little bogans need their hands chopped off!!
Saw a very race spec silver 32 gtr in melville st car park yesterday looked tough!!
Spotted our wagon with new slotted rotors allround along with new pads, thanks to me and Scotty. Also spotted pipster tonight lookn like his wagon has a big dent in RHS front door. Costly!!
Edited by skidkid
been there for a while now :)
just gonna get another door when i get back to qld, strip everything off it, paint it, put my plastic bits on and swap them over
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
