hell yes very keen on the meet up / cruise
ummmmm did i mention i am very keen
think you might have said lol
need to get my 34 brakes on :unsure: guy i bought them off was sold them as 34 rotors and callipers but they are in fact 34 rotors and dogbones to suit 33 calipers on 34 rotors on an adm 31
so anyone who can hook me up with some 34 calipers (dont need pads) let me know cos i need them asap
ideally i'd like to swap for my 33 ones which i have painted in vht anodised effect red
like so
chuck me a pm if you can help
R33 calipers and R34 calipers are identical :)
mechanically yes, but 34's have 14mm bolt holes and 33's have 12mm bolts holes and the 34 calipers sit slightly further out from the hub due to the larger rotor
R33 calipers and R34 calipers are identical :action-smiley-069:
far from it wogboy. they take a 15mm bigger rotor and the mounting bolts are different.
r32 180mm rotor
r33 195mm rotor
r34 210mm rotor and bigger mounting bolt.
i had to drill the hles out on my r32 hubs to fit the r34 gear on. calipers look a far bit different to.
r32 180mm rotor
r33 195mm rotor
r32 280
r33 295
r34 310
sorry late at night
Looks like 'pipster' loves his subway. Spotted wagon parked out front of Mowbray store today, round 2pm. Voted for cruise/meet.
haha, na the gf works there and takes the stag to work
she drives it more than i do, i can see the uni from my room - which is a depressing thought
haha i live nearby aswell and i always see it out the front of subway, now i know why :P
i wouldn't mind a gti-r to run about in - i used to get 10l/100km thrashing about town in my s13, sr20's are amazing
also - dear bp, f**k you. ~$1.5x is a ridiculous price for ultimate, oil is only about $85/barrel and premium in melb/syd atm is 1.30-1.35
grrrr
  • 3 weeks later...
spotted two GTR's in salamanca. a gun metal 32 with 34GTR wheels, with another set as spares on the trailer, I think it was from Vic or maybe qld.
the other was a midnight purple 33 , Top secret (gold) edetion rays/volk LE37 wheels carbon bonnet with do luck front bar I think. They are not stickered up, no targa plates. look like time attack/super sprint cars. had a good hard look around the 33, pretty serious bit of gear!
can't really think why they would be down here, would have thought targa, but the 33 certainly isnt targa legal and not sure about the 32.
Spotted 2x Targa Audis getting fuel. One coming out of wellington st servo, shell is it? Opposite the ladies gym on York St. Came straight out the exit and grinded his front bar on the road... think they'd know they are driving a lowish car?
They were here to attend the John Bowe high performance driving course held at Baskerville on Monday, there was also a Daytona, Evo ix and a 360kw supercharged ford super pursuit ute in their group.
arrr that explains it. I'd like to know what times they ripped out
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
