Hi Everyone
Just to introduce our member's gathering and trips to many wonderful parts of Malaysia. We have few main highways linking North & South part. But to make the journey more fun and exciting to our member, we use the trunk roads which has many twisties and great scenics for us to remember for a llifetime.
Hope everyone would enjoy the picture on the link below..Many Cheers and have a great year ahead!
Edited by driftmeister
Malaysia is quite a safe country to get around, only more precaution needed on your defi meters getting smash & grab. It has been trouble-free for all the trips bcos every members take an effort to get their ride in tip-top condition.
Sure have attracted a lot of attention and awareness espescially driving into many small towns along the way. It has been a great drive and we also learn many driving tips with the more experienced drivers.
:(:):miner:
There are more members converting into the GTR kit, since they can change their wheels to GTR spec & offset, the handling is much better it seems. I had a hard time catching up with that particular car. The cornering seem more flatter and neutral, just on S-Tunes Nismo suspension. The wide & same front to rear wheel combination is nice too.
whoa!!...how come when i go back to malaysia i neva see cars like that?!?!
and about the body gaurds...u know how they have security gaurds with shotguns and ammo around their bodies.....i wa this security gaurd sleeping with a shotgun at a busy bank
We do meet up for gathering every week mostly in PJ area. PM me when ur coming down here.
About the guards, its just the proper security needed for banks and Jewellery boutique. Better to have them then no security at all.
Hope to post our long trip to Thailand coming this March. Cheers!
how much would the Z-tune conversion kit cost all up in RM? Damn you guys look like you know how to have fun :P You are lacking 4 door GTTs but :)
Hi Nismo,
The replica Z-Tune kit can go for RM 6k - 7k depending on availability and finishing (excluding the paint job).
Yes we do have 4dr GTT, feast your eye on this...the front bumper use to be the Nismo GTR type, owner is changing it again to probably the Z-Tune.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
