I turn up with partial noise, then race with lots of noise (it's still below track noise limits though :P)
either way, dollars sent!
I'll bring my earplugs. I know how loud it is, but it sounds great.
  • Replies 701
Posted Images
This question has probably been answered but with 18 pages it may be hard to find.
The first post states that passengers are allowed, however, what is the cost for passengers and do they need a CAMS or Wakefield licence just to be passengers?
If all goes well will be bringing an in car camera setup,with a couple of cameras, to get the front & rear views while driving & maybe one of the driver at work.
Takes a great picture & has fair sound,(searching for another mic atm).
Can have seperate feeds or multiple (split screen)
All gets downloaded onto a memory card as an .avi & can be converted from there.
Maybe be able to lend/hire it if anyone is interested.
sounds like a great setup....best I've got is a dv camera and a lipstick camera.....good but only 1 view.
does it need a puter in the car to run? and what would it cost to hire for a day? or even better to make another setup to buy
WOW.. Just logged in after a long time offline!.. i cant belive how quick this has come up!!
Anywase i have just made payment thru Paypal.*Crosses fingers and prays for spare spot*..
I hope i can still get a spot, if i do miss out i will still be there even if its just to spectate & help with timing etc, wouldent miss it for the world!!! :D
Cheers
Dave
Edited by r33freely
If you've missed out on this day because its full, make sure you come along to this:
http://www.skylinesaustralia.com/forums/in...howtopic=173075
and its a good chance to see how you go against evo's hehe
Good luck to everyone on this day- hope to see you in August!
Cheers,
Mitch
i'm looking forward to it!
just to refresh your memory liz! r32 > r33/s13 :D
Me r32 - 1:17.2990
Liz r33 - 1:19.7580
SCREW YOU!
I recall a certain grid start race where you speared off on turn 2 at OP! lol
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
