  • Replies 701
Posted Images
Are there many out there attending who can lap it in sub 1:10's???
I had a disapointing last weekend with 1:12's in the wet but the car should be back to its usual self by this day.
They are usually pretty leaniant on track noise. We ran with side pipes and no mufflers last weekend without any dramas.
Edited by Risking
You fool! You did a 1.08!
I will be racing no matter what weather conditions as well. Rain makes it even more fun!
QUOTE(Risking @ 19 Jun 2007, 06:38 PM) *
Probably not too many, but who knows, I'm hoping to go quick, but have no idea how quick. I'm looking to knock a lot of time off my last / only other attendance (1.19 in a far worse than stock GTST), now the car is far better than stock so I am pumped.
there isn't any timing anyway... and hand timing doesn't count (according to me.. unless i set a pb, then it counts)
Start timing after you've already gone a quarter of the way around the track! Guaranteed PB!!! :domokun:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
