  • Replies 228
eyy bro when did ya do your engine??
your wheels were just looking and goin sick eyy?
what you do excatly to it?
join the club my donks fuct 2 :dry:
he doesnt know :O he thinks it was too much bee-r but i think it had something to do with the fact he was playing around with the injector setup on the pfc h/c ahaha
#5 has a nice compression of like 60 hehe :(
despite what people think, ignition cut rev limiters like bee-r ones are quite harsh on engines. as you can imagine a huge flame going through the head/manifold and turbo doesnt exatly help things. when i had one on my sr20, i broke 3 rocker arms simply because of the strain it places on the head. Since i have gotten rid of it the engine has never been better
this is true, however the Bee*r limiter only cuts sparks at red line, unless you hold the red line for extended time, the damage will be minimal and gradual.
What Exactly is a Beer Limiter?? can someon Pls explain thanks
-JuLiuZ
what i gather from what ive seen and read, its a devise that cuts spark at a preset rev limit or at the rev limiter, so when you hit that point it doesn't spark, but dumps mass fuel/air into the exhaust and then (i think) sparks as it is exiting(?)
this is why it pops and farts and shoots flames out the zorst and thats why it puts strain on teh engine as exploding fuel/air expands very rapidly, stressing and fatiguing metal
So it's Sorta Like Anti-Lag wif the Back Popping Action eh???? hehe :)
-JuLiuZ
So it's Sorta Like Anti-Lag wif the Back Popping Action eh???? hehe :D
-JuLiuZ
not really, antilag retard timing and works throughout the rev range and does not cuts sparks, allow some fuel to escape....hence more damaging
where Bee*r cuts spark at red line, so cold fuel will exit and detonate at the manifold instead.
I dun get tho, I thought fuel will detonate at certain pressure anyways, the sparks are just there to give a more regular timing
it would but normal combustion engines dont create enough pressue, but thats how diesel engines work, no spark plugs in them
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
