hmmm... it apparently had the wrong oil filter when it came over from Japan a year ago, so perhaps the damage was already done by the previous owner and it just hung in there long enough for me to break it?
I would know if I had starved it of oil because the oil pressure would indicate this? ie driving around with unacceptably low oil pressure.
I will definately make sure it is as terminal as suspected before I replace or rebuild but it was diagnosed by 2 very experienced import gurus... so I have been scratching my head... a lot.
What is the best method of diagnosis, compression test? leakdown test?
But new engine blocks don't have any numbers, so there is no "original number" to bring up. Stamping of damaged block numbers on replacement blocks is of course completely legal, otherwise Nissan (and the other manufacturers) would not be able to sell new blank blocks.
Call me cynical, but in many cases I don't think they even check too closely.. when i bought a car recently I wrote down the engine number on the reg papers - response: "this is not the engine number on file" .. me: "guess it must have had the engine changed then", them: "err, ok, probably, what is the new engine number?", me gives new engine number (not checked.. might have even got away with rb26xxxxxxxxx), and away we go... good 'ol QLD..
Wrong oil filter :headspin: , that makes no sense either. If the oil filter leaked you would know about it, oil everywhere. It can only then get blocked, in which case the bypass kicks in and the oil stills flow at normal pressure. It just doesn't get cleaned. You can tell if that's the case by looking inside the cam covers, no filter = dirty scum.
Compression test or leak down test tells you nothing about bearing condition. Noise is the best test, main bearings rumble like a heavy train on railway tracks. Big end bearings knock, like someone at the front door. As you free rev the engine the noise dies down and as you back off it comes back louder. Once heard it is unmistakeable. The other test is oil pressure, a good quality gauge will fluctuate with bad big ends. The needle flicks around as the oil pressure jumps as it feeds that crook big end bearing.
I suggest you find an old mechanic, he doesn't need to know anything about imports. A big end bearing knock is a big end bearing knock. He will pick it in an instant because it used to happen a lot. A lot of young mechanics have never heard a big end knocking because it doesn't happen very often these days
Hope that helps :D
Thanks that helps alot...
my gf's dad would qualify as an 'old' mechanic lol... maybe time to tow it to his shop... If it does end up being a terminal problem would you go with renowned import specialists and pay the $$$ or go with the family member mechanic who will make the labour costs minimal (is not experienced with modern turbos, though still a good mechanic)?
You make the decision, talk to a few places you would like see do the work, get a firm price and hold them responsible for their work and the price. An engine rebuild is big money. Some say 2k isnt big money, but thats 2 months work for me.
Why is it mechanics refuse to given written quotes, is it a time thing. It would be cool to see a quote that says, Price X in labour, price X in parts so you can compare apples with apples.
Worst case scenario you could be wary of the buck fitty quote as you know they havent allowed for certain things, or you can see that they are actually just good operators with low overheads.
Hope you get it back on the road soon with as little pain as possible. if your car is relatively std, turbo, injectors ecu and boost, then wrecker motors often come with 3 month warranties etc etc. So thats $2000 (?), sell your head etc for $500-700, sell off the bottom end etc, or just throw new bearings in your RB25. A std nissan engine takes a good flogging if you have the std turbo hanging off it.
Talk to ppl you trust and see how you go.
Its not just going to cost for the engine rebuild its also going to cost extra for the head welding which could possibly involve R&R of the valves etc.
Then there's the ECU. You will need a powerfc.
Get the motor in get it tuned.
Run the motor in get it tuned again.
There's a lot more initial money invloved with the rb30 than simply slapping a set of bearings in the rb25.
yeah I've got quotes on dropping a new (wrecker) engine in and pretty much know how much it will cost. I'm not too stressed about that as I know I can have that work done cheaply and reliably and be back on the road relatively quickly.
I just want to weigh that up against going for a rebuild and I really haven't got an solid quotes on that to have made a decision yet. It would be a shame to spend $2xxx on putting it back the way it was...when for a couple of extra grand I could have a relatively stock but tough and tourquey 3L motor?
I guess the first decision is whether or not to pay to have the engine stripped to see exactly what the damage is? ... or just out with the old... in with the new...
thanks for the comments guys...
Oops, i wasnt actually referring/comparing to the RB30 :Oops: , just commenting on how to cheaply /sensibly get the car back on the road :D
I don't consider a 2.6ltr second hand motor a much better outcome than a bran spankin' 3ltr.
It would be more than $1000 to fit as you first have to remove the old motor then drop the rb26 in.
The rebuilt, blueprinted, balanced to race spec (heinz), crack tested (block, rods & crank), forged pistons, multilayer metal headgasket, fitting of the head, cam belt & relocating tensioner set me back $3700.
The head reco, port inlet/exhaust, polish exhaust, roughen up inlet & deshroud inlet valves cost ~$1100.
Total - $4800
+ R&R ($2000) it would come up around 7k.
If you think you can buy a RB26DETT and drop it in without bugger all extra expense think again. Expect turbo's to be replaced and a motor that may have been thrashed or a motor that is a little long in the tooth.
Eventually needing a rebuild with forged pistons anyhow.
People build the 3ltr because they want response, torque and a linear less snappy more tractable hi-po 250-300rwkw+ motor.
Yeah stock second hand GTR motor.. dime a dozen here for around $5k... I wouldn't use a second hand one with stock turbos if I was going to drive it seriously.
On that note I just painted my engine bay and got a new swaybar that goes around my sump so the RB30 will be dropped in and lowered as much as possible. :D
Well I was just thinkin bout the cost of my engine rebuild for RB30DET. It did not cost me anywhere near $7,000. Details...
Note that everything is pretty much at trade price & mates rates prices.
Block $100
RB30E Re-ring kit + bearings + Genuine nissan head gasket $440
Rebuild engine hone block machine crank pins to over size / clean deck block $330 (Mate)
Engine Mount $125
Clutch Plate $105
Exaust Manifold Studs $60
Mate at his own workshop to store car and do work after hours after work or weekend, he supplied everything needed from VCT setup to sending head away to be cleaned and reconditioned with new valve stems / competition fittings for sump for VVT oil drain & Turbo oil drain labour to remove engine dismantle and put all back together was only $2900.00 (+ many nights on the piss)
So totally cost me abouts $4000.
I think I got a great deal from my mate to do the RB30DET Conversion. He basically chucked in a free head rebuild and used new manifold gaskets.. I also put countless hours of work into it doing it with him.. The outcome was awesome but took us 4 months to do.
Pays to have mates in the trade. :P
7k I would think would include a set of Forged pistons.
RIPS from NZ can ship RB30DET's complete with head for around the 4.5k mark.
No 7k was drive in drive out with a $50 wrecker engine without even cracking it open. (developed a engine knock later)
I think he supplier head and turbo and manifolds also. it was a NA VL.
well considering the engine had to be supplied by customer - and thats what he choose to start off with.....
The 7k including head manifolds vg30 turbo rb25 wiring harness all vct setups etc etc engine pulled out built up and installed and tuned... dunno bout the intercooler
That doesnt sound too bad does it ?
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
