I keep comapring all results to Sydney kids original rb30 engine.
475hp on engine dyno, using old t04e and standard everything on 1 bar boost..
anyway.. great results.
Some numbers to think about;
475 bhp = 355 kw
less 60 kw for losses = 295 rwkw
The engine dyno room is airconditioned at 21C , no radiator, oil cooler etc so you don't get as much heat soak as you do in the engine bay of a car on a roller dyno. The intercooler sits in a tub of water (no ice), so the temp is pretty constant. Plus we tuned the ever living crap out of it, spent 3 days on getting the maps absolutely perfect. There might be 15-20 kw advantage in all of that.
So I reckon 297 rwkw at 17 psi is damn fine effort OFENSV, well done.:D
Through a RB25DET 5 speed.
I found it quite interestering the before and after...
No doubt air temps and dyno differences make a difference. But non the less it was interestering to note.
I can't remember exactly how much boost, it was running but it was somewhere around the mid 20's.
For those interestered I went for a little drive and did a complete map trace.
Lots of light load cruise and a bit of spirited driving through the hills.
A few WOT's to 6000rpm also.
RB20DET PFC, RB30DET, Stock RB20DET Turbo that initially hits 12psi then tails off to 8-9psi rather quickly.
interesting piece of trivia:
the 152-tooth Dayco 94407 timing belt is the same as that used on the Audi (Passat?) 1.8 litre twin turbo engines in their newer model cars. it is, however, much more expensive to buy it from an Audi dealer, trust me!
Cubes i have NFI what that 5hit means.
also: the 94407 is 25mm wide, but in the DIYrb30DET guide it says that it is 30mm wide. can anyone confirm that theirs is 30mm?
RPM points are the X axis every 400rpm, starting from 400rpm.
Load points are the Y Axis.
I didn't actually measure my belt. It did however fill up the complete cam gear with only a mm or two to spare, so what ever the cam gear width is is pretty much what the 94407 belt is.
interesting - the RB30 crankshaft drive cog for the cam belt is 25.4mm wide, the same as the RB30 timing belt and the belt i just bought from the audi.
the RB25 cam gears are 30mm wide, as are the RB30. i assume this is to allow for a bit of belt movement as there is no lip to guide it on to these.
are you guys using RB25 harmonic balancers and timing belt drive cogs, or are you using RB30 drive cogs? the 25 ones could be wider?
with my RB30 drive cog there is no way i could get a 30mm timing belt on there, that's all.
yep i'd say the DIY guide is a bit misleading in that regard, all the RB series timing belts are 25.4mm i would suggest.
a 30mm belt would NOT fit on any of the drive cogs, which are just barely the width of the belt. if the belt is enough for a 1.8L quad cam twin turbo it should be good enough for me, using standard cams and springs in addition keeps the loads down on the belt.
i have an R33 DE head - i believe the cams and springs are the same as the DET, only difference is injectors.
I've just had a look at the guide and it doesn't state anywhere the width of the 94407 belt.
It does state that the gates belt has been cut down from 30mm to 25mm in the factory.
I don't really know I used that information from some one else so it's only hearsay.
I'll find that rb20det belt and measure the sucker. :rofl:
hi guys just a quick question about head gaskets. i don't under stand squish zones. i have a rb30 with a r32 25de head, i am going to use stock pistons. which head gasket would be best, what thickness as well?
sorry if this has been covered before.
thanks
Yes that's right, it suits the 1.8L motor used in VW passats and Audi A4's. Going by engine codes they would be the same motor.
The belts costs approx $40 from most auto parts shops.
I'd check my 94407 belt but its stored among the other parts.
well that's sorted - also the front-on picture given in the guide which shows the measurements where the tensioner hole needs to be drilled are spot on cubes, i put mine there and it will tension perfectly once i've tapped the hole.
did anyone use return springs on their two tensioners?
yeah they are locking, i wonder why there's a return spring on the RB30 tensioners, they're the same as the 25 ones i'm 99% sure? anyway i'm using two RB30 tensioners on mine and a friend's 25/30 doesn't use return springs either.
p.s. where do you get new studs for them from? they have two different threads on each end :confused: which is weird, i imagine they'd have to come from nissan..... i shudder to think of the price
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
