FYI - 9mm lift is where the cams require the head to have some material removed for clearance. Duration doesnt affect it. Larger injectors can be bought that fit to the oem fuel rail.
Maybe do some more research...
so 8.5mm lift cams could go straight in ?
what's the best duration to go with this before street driving is gone.
i.e. reasonable fuel consumption and smooth idle.
I was assuming at some point you need the extra lift for the longer duration to be beneficial !
Edited by conan7772
What is a big lumpy cam in an 2.5/2.6 litre, is not so ugly in a 3 litre. The extra 20% capacity smooths the power out a lot. Personally I wouldn't hestitate to stick 264's in there.
As I have mentioned several time, this "machining" to fit higher lift cams is grossly overrated. Plus you can get some serious lft before it is even necessary, I only had to remove 0.5 mm to fit 10.3 mm lift cams into an RB26 cylinder head this week. The actual tolerancing took about 20 minutes with a die grinder. Done in the car, that is not what I call "machining".
:D cheers :D
You've got to get us a sound clip of the rb30det with its cams Ben. :D
I will make a small vid this weekend just for you mate :D
It only has a drop pipe off the turbo at the moment so it's plenty loud.
I made a small mistake off running it without my powersteering lines etc. (no fluid) So my custom made pump kind of stopped. :D
I was looking at my friend.. and said "oh yeah.. the powersteering belt is still hooked up......." BAM! motor stops. haha.
So now all I need to do is hook up my front brake pipes, clutch pipe, power steering and a few other small things and it will actually be drivable.
I have some wheel coming from Japan.. so as soon as they are here the wide body kit I have had sitting in the roof for a year or more will be attached.
Finally getting close fella's! :lol:
Thanks Ben... :D
Well.... I left my water in bung loose and lost all my new expensive coolant upon the first start of my rb30det. :S
Always do something a little silly. lol
Gary,
Howd you go about machining the head around the followers with the head on? Wouldn't little bits drop down in to the valve stem/spring area due to machining? :S
Trying to visualise it.
Edited by Cubes
Thanks Ben... :D
Gary,
Done it a few times, so I have a have a system. I use a vacuum cleaner pointed at each bucket as I grind it. I fill the gaps with grease, which I can wipe off later. I also stick some glad wrap over the rest of the area that I am not working on. As usual it takes much longer to set up/clean up than is does to actually do the die grinding. But certainly better than taking the head off. And it is only 0.5 mm, in soft aluminium alloy, so there is not exactly tonnes of red hot swarf flying around all over the place. It is far more clinical than that.
:D Cheers :D
This is the best place for research...
There's blokes here building engines left right and centre!
Edited by conan7772
what spec cams are you considering ?
my mechanic reckons the 256 deg are the most agro ones you can use before the lobes start to hit the sides of the head...
still don't know if this is for sure yet.
i have the tomei pon cams, so they are 256 degree duration..
bought them before deciding on going for the 3L..
have been thinking of running 264 degree's but still con entirely sure they would work ok on the hydrolic lifters..
i have no problem with getting the "machining" done to clear the lobes, wont have to do as much prep as Gary as the head will already be off the engine.
would solid lifters be better with 264 deg cams? or if im not revving past 7500rpm the hydrolic ones be up to the challenge? is this the same with the valve springs? trying to keep the costs down as far as i can :blink:
would solid lifters be better with 264 deg cams? or if im not revving past 7500rpm the hydrolic ones be up to the challenge?  is this the same with the valve springs? trying to keep the costs down as far as i can :D
My head is off right now but I'm out of money.
Stock cams and the old T3-T4 turbo are back on for now.
Hopefully should get 280 rwkw for the moment.
Next February, aiming for bigger injectors, GT35/40 and tomei cams.
After all this, I'll be content.
Just wanna get 0-100 in under 4 secs.
Edited by conan7772
Not sure..
My mechanic states R34 GTRs all have stock hydraulic.
Don't know their limits though.
GTR's ALL are solid.. R34 GTT is also solid.
0-100 in under 4secs or a flat 4sec.. I'll be happy with.
Possibly RE55s or RA1's + a decent diff and tight subframe should do the trick with... No idea how much power is needed.
Edited by Cubes
see,told ya's this is the best place for research
Stocky give us some pics of your setup!
As for struggling to make 320rwkw with the GT35/40... BS!!
Ive got the GT35R with 0.82 housing and its doing 320rwkw on 16psi :), However the GT35R does look a little 'small' in the engine bay these days :)
GT35R with a .82 on 16psi doing 320rwkw is pretty damn good.
I know of another RB30DET running RB25DET VCT 256 duration cams, nice exhaust manifold and inlet manifold making 323rwkw on 18psi.
Stock exhaust manifold with a .82 machined up rear it would make a shade over 300rwkw with 18-19psi.
Sky30's is pretty much on par also... 312rwkw on ~19psi stock exhaust manifold, 260duration cams.
Edited by Cubes
A pic of my engine in R32 as it is, makes 312rwkw.
Hey sky30 nice looking engine bay man. love the sleeper look.
i have a few questions, how much did you lower the engine mounts by and how close does the engine get to the front cross member now?
and do you have any problems with the bonnet running the standard intercooler piping?
thanks
Phill
Loony Head,
I can answer.
The answers are in the guide, we used the same measurements for lowering the motor. Off the top of my head I can't remember.
There is no clearance issues with std ic piping.
With regards to how close to the cross member.. It sits closer by how much its lowered by. :)
Try not to think to much.. Its all very easy. Simply lower the motor, bolt everything up, extend the dump pipe height a little to meet the extra height.. Thats all that needs to be modified, everything bolts up perfectly.
Edited by Cubes
i've got the GT35R with 0.82 housing and its doing 320rwkw on 16psi
god damn that's pretty phucking good. i really didn't think the .82 rear would get that sort of juice happening without lots of boost. do you have a big arse external gate or just something normal out of interest?
as for pics of mine dave, i'll get some when the manifold has been faced and leak tested, then i can bolt the turbo on and take some happy snaps. still gotta get that goddam M90 drive snout shortened too, and a billet drive pulley machined up :) more $$$
Edited by StockyMcStock
I got a 45mm external gate and i think compression of 9:1
But yeah... Here's what my oil pump now looks like :):
This is meant to be an Rb25det oil pump, when i took it off i found that it does fully sit on the crank drive properly. So maybe this is where the crank collars come in handy? or is this pump just not an RB25det oil pump? maybe a 33/34 GTR pump :S
Either way looks like i need a new one!.. oh yeah.. that inner ring is split in half, cbf hosting the other pic
That looks the same as my rb25 oil pump.
The drive is on the actual crank. I haven't seen a R33 GTR+ crank so I really don't know how it differs.
I assume the motor is now dead? :S
What rev's were being pulled to damage the oil pump?
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
