RE: Patrol RB30
As far as I'm aware they are the same RB30E SOHC.
What is it exactly that you want to know?
Let me try a few guesses...............
Was there an RB30 used in Patrols? Yes
Is it the same as RB30 used in Commondoors and and Skylines? Yes
Does it have oil squirters? No
Is it a 4wd block? No
Are they cheaper than Commondoor RB30? No
Are there more of them than Commodoor RB30? No
Are they rare? Yes
Would I bother searching out for one? No
Hopefully one of those answered your question.
:) Cheers :yes:
excellent ..wow..thanks both I knew if i couldnt find out here then NO ONE would know...once again SAU ....u never let me down.
The reason i ask SydneyKid (Gary?) is because im not in Australia...I'm in Jamaica...if i ask someone to source me RB30 from a GTS they're likely to want to jackup the price on me because of the even the phrase Sk-...if i tell em oh get an old nissan patrol 3.0 carbed engine....they might not be so greedy :) . If they have none here..am I likely to find the RB30e in Japan?
wow respect again for the info. You guys ever think about writing a skyline bible :P
*For R32/R33 with VCT blocked off:
Sydneykid says use a 2.0mm restrictor and block the other one off.
Cubes wants to use 2x 1.5mm holes
If the RB30 has 2x 1.8mm holes, I wonder if only 1x1.8mm hole was
used whether it would be enough???
*For R33 with VCT working:
Sydneykid uses 1x 1.5mm hole and the standard VCT port
MonstaS4 uses 2x 1.5mm holes and the standard VCT port
All that happens if you dont use them is more (too much?) oil gets pumped into the head than is needed when it is better off in the sump!
Edited by VHR32
thanks for all the info guys and good timing to as i am just finishing getting all the parts togewther for mine.
do we have a similar summary for oil pumps and which is the recommended one except for the rb26 n1's and aftermarkerts. eg rb30e, rb30et, rb20de, rb20det etc etc
I'll add to this my experiences.......
RB30 with R33 25 head. VCT enabled.
On the oil drain issue - head oil return is plumbed into the turbo oil return. Engine has been in and running for nearly 18 months without issue.
On the oil restrictors - I originally built the engine with 2 x 2.4mm restrictors plus the 1.2mm or whatever the VCT is. I had heaps of oil out the breathers if i maintained 4000rpm+ for 5 seconds or more.
About 4 months ago i purchased 2 x 1.5mm Tomei restrictors from Greenline. Punched the old ones down and put the 1.5's on top. So yes they fit the RB30. Oil blown out the breathers is now virtually nil. I did get a little (200ml) after a maintained high speed/rev run but otherwise i haven't checked the catch can since.
1 X 2 mm restrictor = same oil flow as 2 X 1.4 mm restrictors
2 X 1.5 mm restrictors = 12% more oil flow than 1 X 2 mm restrictor
The 12% extra flow is why you get oil in the catch can
Hence why we use 1 X 2 mm restrictor, as our cars see lots of continuous high rpm
Also why I don't recommend plumbing the cylinder head external oil feed into the turbo oil return. Driving around town it doesn't matter, but continuous high rpm and it does.
:O cheers :devil:
PS; (for others) the restrictors go in the block not the head.
1. sydneykid when would you consider it worthwhile to do this (oil restrictors). at what power level etc
can you also give me some advice on what size external wastegate would be required for 20/25psi boost. some people say a 38 is mine however others say 40/45 is needed.
would you reccomend cam gears to be done as part of the engine if im doing the forged pistons you reccomended. i presume you get hundreds of pms but we talked re a t66, any luck on pricing?
Suggestions follow;
1. Power level is irrelevant, it's all about how many rpm you use and for how long (continuously) you use that rpm.
2. Some time ago I published the formula that we use for sizing wastegates. I then compared the results from using that formula with over 40 wastegate sizes done by many turbo and other workshops around the country. The results confirmed the accuracy of the formula, with over 90% alignment.
Airflow in lbs per minute = diameter of wastegate in mm X boost correction factor
Let’s use the formula on my own RB31DET
The target is 450 rwkw at 2 bar
450 rwkw = 700 bhp
700 bhp = 70 lbs per minute of airflow = 70 mm (if I was using 19 psi)
I am using 30 psi, so we need to apply the boost correction
70 / 30 X 19 = 44.3 mm
GCG recommended a 44 mm Tial wastegate based on their experience.
This the original thread if you want more details;
http://www.skylinesaustralia.com/forums/in...showtopic=43638
3. PM me about the turbo, there are a few alternatives with the new releases of aerodynamics from the T04Z work.
:) Cheers ;)
Edited by Sydneykid
thanks for your information sydneykid. all your information regarding everything is absolutely invaluable. id hate to know how many engines have been successfully built with some of your information.
im glad i read this thread as my engine would have otherwise been assembled without the restrictors and i probably would have gone with the bigger is better idea rather than listening to any form of reasoning in respect to the wastegate.
where is a place (other than greenline) that you would know of that would stock these restrictors, or is it simply a case of someone being able to fabricate them?
at present my blocks in pieces as is the head waiting to be sent off for some boring. when i get that back ill assemble it all and get back to you regarding a few questions then we can talk turbo. i look forward to it.
As I mentioned earlier..
Hi Octane Racing Australia
www.hioctaneracing.com.au
$15 each inc. gst + postage.
thanks for that
i read in an earlier thread that you were looking at doing gtr valve springs. i was looking at doing the same then read they also werent all that great.
i then called kelford camtech(im in nz) who do most of the countries top head work. they mentioned there are 3 types of valve springs for the rb25 head which i found interesting. they are 10 dollars dearer than the gtr items from nissan.
they are made by an australian company called performance springs and the quality is meant to be very high.
anyone got any comments on how many kws on a 300 kw engine can be made by cam gears finely adjusting the cams?
anyo
Edited by SirRacer
I've been told to steer clear of aftermarket aussy valve springs by many.
Allen engineering, Chris Milton Engineering and Boostworx to name a few.
I was told to either go s/h gtr springs and have them tested or grab a set of aftermarkets from japan.
I went the s/h low km R33 gtr valve springs. Cost bugger all and are all perfect. :rolleyes:
can someone confrim the sentance below re head bolts
"Use a set of 10mm standard RB25DE head bolts. They fit the RB30 block and are the correct length for the GTR head."
i dont want to retap the block until i rebuild it
pete
Edited by fatz
i know the rb25det head bolts go into the rb30 block..i would assume the rb25de ones are identical. 10mm x 1.5P or 1.25P not sure its probably the later being its going into steel so a fine thread is probably ok. Without checking, my money is on 10mm X 1.25P.
I believe next metric size up is the 12mm bolts which are called half inch. So if your gonna retap it, are you gonna oversize to half inch?
I dont know if the rb25de/t head bolts will work with a gtr head. I would say you would just use the ones that came off that head as its the height of the head that matters..so long as the thread size and pitch is the same you should be laughing.
Question for your question, Doesnt rb26 use half inch head bolts/studs anyway? Isnt that why you have to drill and tap out the block to suit the 26's larger headbolts? A 10mm in a 12mm would leave alot of slop.
iI believe next metric size up is the 12mm bolts which are called half inch. So if your gonna retap it, are you gonna oversize to half inch?
RB20/25/30 = 11 mm
RB26 = 12 mm
There are 12.7 mm (1/2"), it's a common size for small block V8's = cheap
:D cheers :D
Edited by Sydneykid
ahh so half inch studs/bolts actually are close to half inch..not just closest metric equivalent full value.
I swear someone called the 12mm head bolts/studs half inch even though half inch is 12.7mm.
Isnt 11mm an odd size since most bolts and studs come in multiples of 2 unless you go relatively small.
Yep, that's why the 11 mm studs are expensive compared to 1/2". The 12mm ones are expensive because they have RB26 written on the box.
:D cheers :D
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
