Read again mate..
"Having the high-flowed stock turbo was always questionable, but even more than before the conversion, it spools up so quick and holds 18 psi efficiently"
He said he got 300kw at 18psi on the high-flowed stock turbo ...
haha i did read again .. how about you?
Stock hi-flow making near 300rwkw on 15psi............. are you sure?
My 35/40 only cracked 300rwkw on 18-19psi.
Yeah, that looks very similar to the hi-flow i had on mine, but i only made 235rkw on 17psi with similar mods.
Have you had yours on a dynodynamics dyno?, be interesting to see the difference compared to the dyno you used.
Only when I first bought it.
I had different mechanics who stuffed up the fuel maps even more.
It showed 192 kw on a MDXDyno.
Had bad burble problem , the car ran horribly compared to when I had it tuned at Joviant Performance, came back at 247 kw off the hub.
It would be interesting to see the difference.
What fuel are you running?
Turbo specs?
What fuel pressure are you running? :thumbsup:
Vortex
Turbo specs editted in the results thread
Will get back to you with fuel pressure, haven't been game to take my eyes off the road yet.
Mechanic says I still have more pressure available but he's worried about the injector seals leaking.
Apparently stock ones have done this.
Also will post an in-car vid soon as soon as I can find a way to hold the camera still.
Don't want another video of ugly feet...
Turbo specs?
Vortex
did you do any other work to the motor, cams or port/polish etc?
still awesome results though mate.
That turbo doesn't look like a t3/4 at all. :thumbsup:
It runs what looks like a 6blade comp wheel, notice the turbine wheel location has had the sh*t machined out of it. To myself.. It looks slightly bigger than a GCG highflow item, well the turbine side appears to be machined more so and its not running the crappy 7 blade comp wheel, its possible its running a gt3040 or gt3076 core or something.
I've been told it is possible to fit the 60mm turbine wheel in the vg30/r34 turbine housing by ATS here in Adelaide. I believe GCG use a slightly smaller turbine wheel than the better 60mm item.
I do suspect the turbine housing you have there is the slightly larger vg30/r34 item as on the rb25 it comes on around the 4k mark, on the 3ltr that would be around the rpm's you are talking.
EDIT: I've just had a really close look at the turbine housing, it does appear your not running the gt30 turbine wheel as I can see a slight lip, I measured the opening on my rb20 and vg30 turbine housing and for a 60mm turbine wheel to fit in there there will be no lip.
None the less the power is up there, its not like it will be making 200rwkw, its obviously around 250rwkw possibly 260 nudging close to 270 on a run of the mill dyno dynamics. ;)
Thats based on sensible (well not that sensible) fuel pressure through the stock injectors. Any more than 250-260rwkw and its just a matter of time. :ermm:
Stock cams, block was bled down, bored and honed 20 thou over.
Stock springs, completely stock head.
Forged pistons rods and rings.
That's it.
That's it.
conan7772:- What RB25 head are you using? R32 n/a 0r r33 with vvt?
Is that 294kw at the rear wheels or what, never seen that before with stock injectors.??
Darren,
What power did yours make and at what boost?
never had a proper tune done really. First time it went in the cas was farked, so it only made 208@1bar, then went back and had a fiddle it made 218 @ 1.1 bar.
The coil packs are gone now (were on the way out before) and the highflow wont get a proper exhaust (cos im going to wait fer the bigger turbo)....but yer it could do the same as yours did @ 240 easy if i wanted to fark with the setup.
seeing as there are some knowledgeable people here...
how would you guys run in a brand new engine? It's been suggested that I run it in on the dyno, can anyone shed some more light on the implications of it?
here ya go ...
http://www.skylinesaustralia.com/forums/in...ST&f=8&t=110618
specifically the post i put in post #22
dyno runs are good, but think of the time on one, to get the 600Kms or so before you can start tuning it completely..
im guessing if your changing the motor, making sure that the AFR are good up to the level of RPM that you want to run it in with. then do the long drive run in process.
there are alot of different ideas on this... also remember to prime the oil pump before you start it...
been a few posts about this lately.
Just confirmed the following , Dynapack and Dyno Dynamics are both accurate but will read different because of their design.
Dynapack is measured at the wheels and is preferred by some because it is quicker to tune on and more sensitive.
Also doesn't have traction issues.
hoping this is the best spot to ask this question...................got myself an xr6t today and have just been working out what i need to bolt it up to my standard rb20det manifold on my rb30det so anyone who was done this on an rb25det or rb30det please help me out!
1.) So far i've worked out i need a new dump pipe (different flange!)
2.) New oil and water lines (not sure where to get these from or what exactly to ask for!)
3.) 90 degree bend welded on the inducer/cooler pipe so it faces the front of the car for the standard cooler piping. (figure this would be better than using a 90 degree bit of silicone hose)
4.) do i need to rotate the front housing on the exhaust housing??????
Anything else that i've missed or needed please let me know.
I also have the standard na valve springs (R32 rb25de head) and only a GTR fuel pump. These are the only 2 things on my engine that i think could be a possible weakness. Do you guys think these things should be fine or should i upgrade these first. The car has been on the dyno not too long ago and the valve spring were showing no sign of floating and the fuel pump was said to be up to the task with the vg30 turbo.
Any thoughts on these things are greatly appreciated!
cheers in advance, Ash!
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
