how much is it for a 4wd sump adaptor?? how much do the prices vary? i know RIPS in NZ make em and one guy on here (forgot his nickname) and sydneykid said his fabricator makes them.
i want one that fits first time with no mods at all.
also could i use my rb26 power fc djetro on a rb26 head/rb30 bottom end? how do i go with the difference in knock sensors on the rb30 bottom end? do the rb30s use 1 or 2 knock sensors?
cheers
Brad
Edited by CruiseLiner
cheers
Brad
RB30 uses ONE knock sensor in the middle. BUT they have the provisions for the 2 knock sensor in the standard position from the rb25/26 so they bolt straight in.
question for Sky30 . or anyone who knows
what rear housing are you using on the GT3540 ??
and have you got a newer dyno sheet than the one you posted in the RB30 results thread?
Im using some kind of .82 truck housing with internal gate machined to suit GT35/40.
No further results to that dyno, that was running stock plenum and stock exhaust manifold.
Thats is a good result!!!
Wondering if anyone has solved the bonnet clearance issue??? I have now been driving around with my bonnet open LOL and i dont want the cops to pull me over...
is it hitting the support bracing of the bonnet or the actual bonnet skin?
I have cut the support braces off, its touching on the bonnet itself where the corner of the inlet manifold is... i really dont like driving around with my bonnet half open LOL
Fatz silvia special?
:cool:
Take it to a crash shop and ask if they can nicely put a controlled dent in it or something.. Looks like you may have to go some sort of bonnet scoop, shell out for an aftermarket plenum or thought about grinding the plenum yet?
Have you tried to space the rear of the bonnet up using a spacer between the bonnet and hinge?
Or space the engine crossmember down a bit using some big washers?
Yer i tried spacing up the rear of the bonnet and didnt work, im not going to play with the cross member for obvious reasons, looks like its going to have to be a bonnet scoop...
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
