Interesting.. Whats with the 2 lumps in front of each cam shaft on the cam belt then? :P
It was an N/A that I had a look at, I wouldn't have thought the turbo head would be any different.
??? The cas still bolts to the front of the exhaust cam, but it has a different spline
Are there any differences in the 26 and 30 headgaskets?
I have a VVT 25 head thats had the front right water jacket and oil gallery welded up and the water gallery shaped to suit the 30 block.
There appears to be more thicknesses available for off the shelf MLS headgaskets for the 26.
is there any issues running the RB25 gasket with the rb25det head?
obviously the oil feed is different, and will be modified for VCT externally..
Nope. I'm running the Cometic RB25 head gasket on mine without issues (~40,000kms). The price difference between the rb25 and rb26 was considerable at the time. I got mine from memory for $150.
Nope. I'm running the Cometic RB25 head gasket on mine without issues. The price difference between the rb25 and rb26 was considerable at the time. I got mine from memory for $150.
i got mine cheap but not THAT cheap ...
the rb25 cometic im running on the rb25 in the car cost me $330 :D
got some ACL piston rings, so its almost wash and build time :O prob 3 weeks
Thanks for that Cubes.
I've been looking at the cometic and ACL race series MLS gaskets, Prices ive got ranged from 210-350 for an RB30 MLS headgasket.
Its not really an issue with a 33 25 VVT head that I've seen but there is a 1-2mm of sealing on a particular spot on the front right water jacket. That is when you use a 30 block.
Just to be on the safe side I tigged the water jacket and VVT gallery up in the head and shaped it to suit the water gallery in the 30 block. Theres a min. 5-6mm of sealing now.
It was a better option that trying to braze weld brass to the side of the block like in this pic.
http://www.users.bigpond.com/twinvl/blockmod2.jpg
I heard the Non turbo rb30 pistons have less rings or sumting like that.. and dont cope with boost very well...
wen i was gonna turbo my rb30e, i was being told that the compression had to be lowered a fair amount from 9.0:1 to around 7 or 8:1 to stop pinging and detonation...
Why is it ok for a hybrid motor to have higher compression ratios? wont it ping/knock its tits off??
Jimbo
Whoever told you that didn't know what they are talking about
Jimbo
Jimbo
putting the 25/26 head on actually lowers the compression!
1. Because its a hybrid motor. Better designed head that allows you to get away with a little more static comp. :)
2. Its all in the tuning. Simply throw a stock rb30et ecu on an rb30e that has a turbo bolted on to the side of it and try to push 14psi through it and it will almost certainly detonate. So tuning tuning tuning.
So the guys running the R32 RB25DE heads. What sort of power are you guys putting through the inelt manifolds...has anyone gone to an aftermarket one and noticed an improvement in response/power
Hey fancy seeing you in these neck of the woods. :whistling:
AM-Performance is about to drop an aftermarket plenum on his within the next week or two.
Sky30 pushed 312rwkw through his r32 rb25de head running the stock exh. manifold and stock inlet manifold/plenum.
Thats the highest I know of on the R32 RB20/25 style plenum.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
