Hey rb30det guys, is it possible to bore out the rb25 block and use rb30 rods and pistons to make an rb30det?
It has been done.
It requires modification of the rb30 crank (destroke), rb25/26 rods and custom pistons.
All though not optimal as the rods would experience greater side load and the piston pin height is bugger all.
But it has been done and appears to work well. I believe the bloke made some where up around 400rwkw and had 8000rpm on board. I'm curious as to how well its holding together some months down the track.
The bloke who did it I believe is mark99. He's in Adelaide.
Hey guys I'm building up a rb30det, I'm ready to start bolting it together just need a head gasket and an oil pump.
What head gasket do you guys recomend, How much and where can i get it? I was looking at a Cometic 1.2 mm metal on this site on a traders forum but now i cant find it again :laugh:
And whats the diferance between the GTR and GTR N1 oil pumps? Is it worth spending a little extra on the N1 pump and why? Also where can i buy one i been told $410 from this site?
What head gasket do you guys recomend, How much and where can i get it? I was looking at a Cometic 1.2 mm metal on this site on a traders forum but now i cant find it again :D
N1 pumps for $410
here - http://www.skylinesaustralia.com/forums/in...howtopic=133537
cometic gaskets
here - http://www.skylinesaustralia.com/forums/in...=131709&hl=
We blew our rb30det :sick: Im pretty confident the n1 oil pump has either rattled apart or the gear has cracked. Will know later in the week when its all pulled down. Its a sad sad day, hopefully its not as bad as it sounds, but she is ceased up completely so im expecting it to be almost totally screwed.
ouch, ouch, ouch... really sorry to hear that. :sick: Plus it makes me nervous...
Very interested to hear if its related to N1 breakage...
I dont know at the moment....Depends on what caused it. But either a brand name one or perhaps a dry sump setup which would be nice. Saturday was the most expensive day of racing weve had so far haha.
How many k's had it done?
I'm fairly nervous with my pump.
No crank collar and its clocked up some where around ~45000km's.
I went the std rb25det pump as I remember at the time my thinking was the N1 pump with its higher relief will place greater pressure on the small crank drive.
Just pure bad luck R33_racer.. :D
Are you running an ATI balancer?
yup...but our car gets thrashed more then a street car would....all day at the track its at or near the max. Yeh we are actually, thats where im lost. I made sure we took almost every precaution available to make sure this wouldnt happen. Collar, everything balanced and ati damper. But we didnt loctite the backing plate bolts in or anything like that, we just bolted it up and left it assuming it was right from factory....so i think thats our mistake unless its a fault with the pump itself.
Im not 100% sure if he does. I think i remember a thread from ages ago where he said he made his own dry sump setup from second hand bits for cheap which they ran on one of the cars. not sure if it was his or another one. Would be interesting if it was on one of the rb30dets. hopefully he will come and explain it to us :D
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
