Finally got around to getting some pictures of the dry sump setup in the race car....its still not finished yet...but its making progress. We gotta mount the ally pipes under the car after i tig on the -16 ends and then mount the tank and finish off that end of the hoses...check out the mass of speedflow crap!
post-12828-1166694939.jpgpost-12828-1166694960.jpgpost-12828-1166695006.jpgpost-12828-1166695026.jpgpost-12828-1166695046.jpgpost-722-1129090407.jpgpost-12828-1166695087.jpgpost-12828-1166695111.jpg
Last one is just a new power steering reservoir i fabbed up. Shiny!
Fun making that all fit. Try it with 2 more lots of fittings on the pump. Nightmare.
so does anyone think it could be anything else the symptons are no smoke in 1st 2nd or 3rd hit about 120km in 4th and she just blows smoke absolutlely every where and will continue to trail smoke in 5th, after this it will some times blow smoke in lower gears but only when giving a squirt, it seems to run quite well untill it dumps all the oil in 4th, any chance this could be a problem with the way the motor was setup? or most likely valve guides.
if it is valve guides is it worth while to upgrade to gtr valve springs or are the r33 rb25det springs more than adequate? and lastly on head gaskets any dramas with a nismo 11044-rr590 Gasket Cylinder Head - 0.9 mm x 87mm
try doing leakdown test, that might provide some clues but won't show worn guides. if its a bit of an unknown quantity it's worth checking as much as you can so you know what you've got. if the mech says valves then I'd go with that, if it's still at the same place those guys seem pretty good . gtr valve springs are not as good as a set from Performance Springs for $250. nismo or cometic metal head gasket will be fine as long as it's the right thickness. head off will give you a good opportunity to check CR also, no point running 7.5:1
as R33 racer said oil returns are gravity feed and can cause problems if not plumbed correctly. all of the hoses should facilitate flow by 'pointing downwards' if that makes sense ie don't have a hose that tries to make the oil run up hill.
valve guides only blow smoke first thing in the morning as the oil drips down overnight then burns off when u first start the car in the morning. If it was valve stem seals u shouldn't see smoke after that initial start.
This was one of the reasons Cubes and myself spent extra to get the head recon'd before the bottom end was built. No point having a fresh bottom end then slap on a 100k+ old head on it
Try a leakdown test, then look at the turbo.
Edited by Bl4cK32
If the inlet valve guides/seals are worn, it will blow smoke when accalerating after decel, such as after going down a long hill, as the inlet manifold vacuum sucks the oil past. Exhaust guides/seals will blow smoke on startup, but not leave any residue on the plugs. Is there oil in the intercooler piping, any residue around the exhaust housing. Have you done a comp test, or is there much blowby out the breather under load?
yeah there's plenty of oil in the intercooler piping, i've also changed the turbo over with another stockie that was the first thing i did and yeah didn't fix it.
The car is running quite well needed a car to drive the other day but on a 30min return trip it went through heaps of oil which was surprising cos it's wasn't blowing to much smoke, put a bottle of stop smoke in it just for the hell of it and it's has actually lessened the smoke but it's still quite bad so it got parked straight back in my drive way
the oil line from the head is pretty much a straight T into the turbo return line the oil never travels up only horizontial but it does have to do a 90 degree turn
had my mechanic drill and tap the head, then put a grub screw inplace of the original vct feed, then drilled and tapped into the front of the gallery behind the inlet cam gear and put a fitting in there for me, all i need now is some braided line to go from the oil hole behind the oil filter to supply it with oil, as the rb25 oil cooler assembly houses the std oil pressure sender, where as the rb30 used the hole behind it.
dont have pics here though
did you have to weld shut the oil feed port on the block, and did you modified the coolant port on the block to match the r33 rb25 head?
guys i need some help with find a bloody timming belt, ive try'd just about every place in australia.
Ive put my second tensioner in stock position, motor is together so i dont want to drill and tap holes.
All i need is a timming belt: 1200 long, 150 Teeth with a 8 mm pitch 25 mm wide to fit on the rb cam / crank gear.
Sound symple? well its not!
The gates powergrip 1200 8mgt belt is an industrial belt and does not fit on the cam and crank gears. All automotive belts have a tooth number but no length and no pitch information... so how the F$@* do you find a belt?
P.S Both the bosch and Dayco belts on the SAU PDF are 152 tooth for use with relocated tensioner
Edited by kaige
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
