Ok , so from reading this im guess a rb30(n/a) bottom end will not just bolt straight in....
i have a rb25det (automatic) in a R33 gtst i dont wanna change driveline .
Will my box fit? will the engine mounts match ? its a great thread but im just looking to bolt on the rb30 bottom end without changing pistons and grinding galleries? is this possible???
thanks in advance
Edited by Veilside-SaU
Im pretty sure all spigot bearings are the same. rb30, 25, 20 and 26 identical. Ask for an rb30 spigot bearing...chances of finding that are probably better as its from an australian car...some automotive stores dont know any better. Ask for a 26 and the list will only say rb30....and the pimple faced kid behind the counter will say 'sorry sir the computer only lists one for an rb30 out of a vl commondore, cant help you...'
Idiots...annoying sometimes.
RE: Belt sizes.
Just been looking on dayco.com.au, heaps of belt options.
94843: 153 teeth, STP8M pitch, 25mm wide (not that it needs to get any longer)
94407: 152 teeth, STP8M pitch, 25mm wide
94604: 151 teeth, STP8M pitch, 25mm wide
94777: 150 teeth, STP8M pitch, 23mm wide (this belt is equiv to gates t306,150 teeth)
94830: 149 teeth, STP8M pitch, 25mm wide (pretty much spot on for low low setup)
94109: 148 teeth, STP8M pitch, 25mm wide
94652: 147 teeth, STP8M pitch, 25mm wide (getting a bit short....)
Hope this helps a few people, Im gonna work out the best one for the low low tensioner setup for mine, will post up results.
Edited by Godzilla33
hi guys i have these pistons
AP340754 Arias - Arias Forged Pistons Rb30 Non-turbo 86.5mm Bore Supplied With Rings
how good are they for this conversion???
what comp ration would it give with 1.5mm head gasket and rb25 vvt head?? and the block has been faced if that makes a big diff (not sure how much tho)
the non-turbo pistons are better for this conversion yee? or is that just the standard non-turbo pistons which are better??
whats teh differance in strength between the turbo and non turbo pistons?
Hey Scooby,
yeah, pitch is the same as std RB30 belt, Im 99% gonna use the 149 tooth option with the low low 2 tensioner setup. Gives that bit more clearance between tensioners. My local Repco doesnt stock dayco, gonna try get one tomorrow elsewhere.
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
