The tuners still have our car...been there all week. Car wont make more power then about 290rwkws and it keeps overboosting once it reaches its target boost. They have been playing with timing, and wastegate springs....they think the problem is a faulty gate, which is sticking or something...so another is coming from turbosmart which will hopefully clear it up.
Initial thought after playing with wg springs was that the timing was out a few degrees, as in piston was not tdc when we set it up...But now the blame has been shifted back to the wastegate. Hopefully it gets sorted cause races are next weekend. Car still needs a wheel alignment.
R33 Racer- What size wastegate you using?
48mm turbosmart progate....the exact one we used previously on the old motor before it died.
The only different things on this new motor is the dry sump system, gt3540 0.82a/r, 4" exhaust system, oh and not that it matters but argo rods(previously ran rev)....so it went from making 370rwkws to 290rwkws.
with 8.5 to 1 what does a compression test come out at? mine has 120 in each cyl and i was wondering what it was.
comp ratio is 8.5:1
had several bolt on probs previously to this run, which I ve recently sorted, bent plenum, fuel pump issues.
But fixed all those, new 044 pump etc. No leaks, A/F ratios all good now.
I agree cubes, I told Matt that this Friday to boost it until it pings :-) , as the engine will handle near enough what ever we put into it.
Ill be running 100 octane and I wont be happy if it doesnt make some serious power.
And if it doesnt Im not sure where to look as Ive pretty much sorted every other issue that has come along.
Feel free to suggest anything - because at 10 psi I really thought it would be making more power, I guess if I pump 25 psi in on a proper tune it might make what Im looking for....but who knows until Ive done it
I dont think compression ratio and compression pressure have a direct relationship. As there are many variables that effect compression pressure, ring end gap, bore wear, ring wear, valve to seat seal etc.
So you can have two engines with 8.5:1 but both have different compression pressures.
This might be a silly place to ask i dont know, but what motor would best suit a r32 gtst with standard diff ratio (4.3)
I have a standard bore rb30 bottom end waiting to be built into a 3.1 but always wonder if i would be better off with a 2.6,7 or 8.
Both motors would be fully built with 9.0:1 comp ratios
Thanks guys
r33 racer what diff ratio are u running and how do u find it etc.
just after some info
want to run forged pistons with approx 9:1 comp ratio
and fit oil squirters
can i buy rb30 pistons or will i have to use rb25 with oil squirter cut outs
why bother with the oil squirters when people in the know ahve said u dont need them?
to quote a very repuitable shop, RIPS, taken from ww.gtr.co.uk:
Originally Posted by Sayajin
How difficult is it to put the RB26 oil squirters into the RIPPS RB30 block? Is it even necessary with forged internals?
Originally Posted by RIPS
Not required. No piston failiers, ever.
I installed the new wastegate springs in the HKS gate on Sunday. Hooked all back up and went for a drive and it was still only making .7 bar. So I turned off the AVCR, still only .7 bar. Then I plumbed the wastegate up straight to a boost source, so it had nothing to do with the AVCR, still only .7 bar. Getting a little annoyed by this time, so I totally disconnected everything to the gate. Thought I would go for a very cautious drive to see if this gate was working at all. Full revs still only .7 bar, so Im guessing ( havent had a chance to remove it ) that the valve is either not seating on the seat, or its stuck open.
There are no leaks in the intake side as I pressure tested it again yesterday.
Any thoughts on other reasons for no boost ?
yeah they finally released it, actually useful data for once
pitty it needs to much damn turbine speed to get anything useful from it
whats a realistic rpm we are talking to get a 0.70 a/r housing fast enough to make the compressor flow 1.5 bar. is there a way to mathematically work this out?
given that we know required turbine speed and pressure ratio ?
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
