...as well as those N1 pieces of junk.
Hi Geoff, you're not a fan of the N1 either? After much deliberation and discussion with Greg, as well as Harris Engines, I've used one. They both seemed to think that while N1s don't like to be bounced off the limiter repatedly or spun to 9k rpm, they're otherwise OK.
Not a fan because the N1 is a much more brittle material so doesn't have much residual toughness for things like bouncing off the limiter, but that does happen even if you don't want it to.
Also there is no real justification for much higher oil pressure/flow. All it will do is deposit more oil in the head which you then have to get back to the sump for pickup. Oil system function and efficiency is not based upon the amount of flow or delivery pressure, but the maintenance of the thin film of oil between moving metal components. Oil pressure does not provide lubrication; oil presence and viscosity does it. Some systems use the natural viscosity to pull the oil through without a pump.
It would be great to know that the flow is moving the oil through to prevent overheating and molecular breakdown, but pressure is always a measure of restriction when it comes down to the final analysis so a high flow pump giving greater pressure head is simply showing the restrictions present, and therefore the lack of ability of the high flow pump to really make any discernible impact.
As stated previously, i have already purchased an ATI balancer. I came across a thread that discussed GReddy pulleys and thought they may come in handy if they are able to be fitted to the rb25 p/s and a/c pumps.
So i went to Nengun to see how much these GReddy pulleys where, and stumbled across a HKS balancer that i reckon is actually the ATI balancer (Nengun Link - CLICK HERE). What do you guys think?
Now reading the Nengun description got me a little concerned:
...........To install this item, a Mitsubishi alternator must be used (Hitachi's alternator is not supported).
The Mitsu alternator only came out on the S3 R33 GTRs and above. I would like to know what is the difference between the Mitsu alternators and the Hitachi units? As the GReddy pulley kits also distinguish between the two makes.
10 psi
220rwk@6500 power curve flattened out so prob not much left. Rich, dipping into 10:1
Running really rich also on part throttle when bimbling around, 2nd gear 40km/h etc. Can hear a very slight unneveness/burble but very smooth on boost. Not sure why this is since it's the stock ecu.
Guys any ideas on the part throttle richness? Didn't happen with the RB26, not sure why it should be so rich with the 30 using the stock ecu. Actually feels really unresponsive at part throttle sometimes, almost like it's taking its time to figure out what to do. Once at a certain throttle opening it's 'off we go'.
Cheers
I think I also had the same thing on the stock rb20det ecu. Not sure if it was rich or what not but it felt as if it would bog down slightly then lunge off. It wasn't all that noticable.
I dropped in the pfc and it was 100% perfect on its base map.
question:
rocket industries says that with arias rb25/30 forged pistons comp is 9.5-9.8:1 (part #ap332105)
and with standard rb30 nonturbo forgies the comp is standard (#ap340754)
which would be better? is 9.5:1 too high? and does everyone agree the information is accurate?
forgive me if this has been answered as im only up to page 160 of so in reading this..
thanks
edit: all good, found this
but is 9.2-9.4:1 too high comp?
QUOTE(VHR32 @ 7 Mar 2007, 12:12 AM)
I updated my piston list from P221
Added a new p/n for a flat top piston from Arias and added compression ratios for the Arias pistons. Two are quite high for a turbo engine!
CP
All compression ratios are based on zero deck height, 1.2mm head gasket (7.13cc), RB25 @ 62.5cc, RB26 @ 64.5cc. They assure me they have done alot of work to make sure the facts are correct.
p/n= CP-RB30/26-.20
Flat top with no valve pockets
8.2:1 COMPRESSION RATIO with RB25 head and bit less with RB26 head
21mm pin
1.280" compression height
Only stocked in 0.20 thou oversize but can be custom ordered in any size.
p/n= CP-RB30/26-.20-9.0
6.0cc dome top,
9.0:1 COMPRESSION RATIO with RB25 head and bit less with RB26 head
21mm pin
*Care must be taken when using on RB26 with more than 11.5mm valve lift*
ARIAS
Suit RB30/26
p/n= AP332103
flat top
21mm pin
Only stocked in 0.20 thou oversize (86.5mm).
COMPRESSION RATIO 8.4-8.6
Suit RB30/26
p/n= AP332104
10.6cc dome top
21mm pin
COMPRESSION RATIO 9.2-9.4
Suit RB30/25
p/n= AP332105
13cc dome top
21mm pin
COMPRESSION RATIO 9.5-9.8
WISECO
Skyline RB30 w/ DOHC RB25det cylinder head
1.260" compresion height, 66.5cc head chamber, Dish top -11.3cc, 7.0:1 compression ratio, 21mm pin, 1mm gasket thickness, 1mm deck clearance.
K577M865 86.5mm
K577M87 87.00mm
ACL
6MKRY9608 (VL turbo)
87mm, -4.5cc dished top, 1.261" compression height, 21mm pin,
Standard RB30ET pistons are 7.8:1, with RB25 head it is 7.1:1
These are bumped up to 8.5:1 so with the RB25 head it may give about 7.5:1??
Using http://www.csgnetwork.com/compcalc.html I came up with 8.5 for VLT (spot on) and 7.6 with twin cam head with 64cc chamber.
I entered: 2, 87, 85, 87, 1.2, 64cc, -4.5cc = 7.6:1
BUT these have a lower compression height than the CP/Arias and im sure it stuffs up my calculations but its late and im too tired to look at it any more...
Edited by silver gts-t
That's exactly what mine does. Making enquiries now about getting an ecu remap.
Wow, a VL engine in a beefed up R33 - what can I say... wow!
Do you have photographs mate? Would love to see what your best looks like... one thing that really intrigues me is that if people that are after the "GO" why important is the "SHOW" to them.
Good luck with the build mate....
Cheers,
I just tuned one of these last week. RB30DET using RB30 bottom end and RB25de head.
if you are using the standard R32 ECU an AFM you will expierence this at 2400rpm when cruising and then get on throttle. then it will start to pick up at around 3200 rpm. the 2 factors that make this happen is the RB20DET timing map. bugger all advance. engines need timing to make torque :( also the AFM reads a lot more flow than it would with the 20det so the TP scale is out by about 30%. this makes the tune rich.
The combination of the 2 things make it a slug. if you put it on the dyno you will see what I mean. I ran 18deg timing on the one i just tuned and corrected the AFR and it came on boost a lot earlier and increase response and made power delivery a lot better :)
This does not happen with the RB20det because it never accesses the far right TP scale at 2400RPM :(
It is quite ease to make some minor adjustments to the tune to get it to run the 30det nicely.
if you are using the standard R32 ECU an AFM you will expierence this at 2400rpm when cruising and then get on throttle. then it will start to pick up at around 3200 rpm. the 2 factors that make this happen is the RB20DET timing map. bugger all advance. engines need timing to make torque :D also the AFM reads a lot more flow than it would with the 20det so the TP scale is out by about 30%. this makes the tune rich.
I have an RB26 ecu.
Edited by Scooby
Cheers
The extra capacity (15%) and the better cylinder fill from the longer stroke and superior rod/stroke ratio means the RB30 is using parts of the standard ECU mapping where Nissan considers an RB26 would never go. At 2,000 rpm an RB30 swallows just over 20% more airflow than an RB26, so it has airflow at 2,000 rpm that the standard mapping doesn't expect until 2,400 rpm. Nissan has programmed into the mapping considerable safety margin in the form of retarded ignition and rich A/F ratios whenever the engine gets outside its normal operating parameters. That's why I would never recommend running in an RB30 on a standard ECU, the richness will stop the rings bedding in properly and in extreme cases lead to glazed bores. The retarded ignition results in incomplete combustion which fouls up everything from plugs to cats.
A Power FC on the defaults maps is a far better solution as they don't have the "outside the normal" richness and retard mapping, there is a more logical extrapolation of the "normal" mapping. Just have the knock readings permanently displayed on the Commander and watch them closely. If you have an A/F ratio meter just keep an eye on it for excessively rich or lean readings. Otherwise spend 20 minutes on the dyno and check the readings.
:) cheers :whistling:
:huh: cheers :thumbsup:
much more accurate description than mine :(. Looking at the standard RB26 map, the AFR's would be 10:1 if using an RB30 bottom end and putting your foot down at 2400rpm.
Hi, like everyone has said bloody great thread, im only upto page 60 or so but give me a week and i'll be up to date :D
I've decided to jump to the last couple pages to see if anyone has discussed using the r34 neo head so i've just go a quick couple of questions. I've read the rb30 DOHC guide and it says that the water/oil galleries are different in the r34 head and the head has less cc's at only 50cc.
So...
1. Has anyone done a rb30 neo conversion?
2. How different are the galleries? What needs to be done compared to the r33 head?
3. What is the compression ratio with the r34 head like?
I have a r34 gt-four (you would of never of guessed with my user name haha) and this is looking very attractive, i also realise that an adapter needs to be bought to fit my sump onto the rb30, but its been done before with the r32 & 33 gts-4's so it shouldnt be to hard
thanks
There seem to be a lot of people using the RB25de heads and not replacing the valve springs.
is valve float related to pressure/boost or flow aswell. does anyone have a rating for the RB25de, RB20det and rb26 springs?
are they all interchangeable?
thanks!
Its boost/rev's related.
The rb26 springs are a couple mm taller + which helps with seat pressure.
Out of 4 motors here in Adelaide there's only 1 that I've seen that has been untouched and had no issues at 20psi. The other 3 required shimming to get seat pressure up to a working level and the other one (sky30's) was fine until around 17psi.
The rb25de springs are identical from what I can see and feel to the rb20det springs. The issue occurs because the spring is attempting to control a valve that is larger/heavier.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
