we got sks package and then i pinched the tops off the teins and used them since they were spherical bearing, not rubber.
Before we changed to SK's deal, we put softer springs on the teins, and i must admit that helped a little bit but it was still stiff...which led me to believe that the shocks were still crap in terms of their valving, from them to the SK's was a massive improvement all round. Had to play with spring rates abit, but nothing too major. However the aussie spec ones seem to be loads better over the jap ones.
We are way off topic here, talking suspension in rb30 country.
Edited by r33_racer
A question for the guys that have been driving around with the RB30 hybrid motors....
Have you had any problems with the bottom end strength ??
I have been told by 2 experienced RB26 mechanics (one worked in Japan for Nissan) that the RB30 bottom end wont handle high boost and is the weak link. I'm not sure if this is just because they are RB26 biased or if its in fact true...
It wont stop my build, i'm just curious.
lol; no. Which has reminded me; its time to update it. :)
The blokes are Boostworx are top blokes; always done the right thing by me from the start so its well deserved.
There's so so many workshops out there that simply do not give a sh*t.
ok guys i need help im only a newbie....
i am currently rebuilding the rb30/25 to put into a lh torana 4 door.
i have read the first 86 pages in the last 2 days and i just need to ask one thing...
i am going to buy a rb25de engine for the head and bolt on acc, though can i use the non turbo loom in a turbo application with a power fc?? or should i lok at buying a rb25det wiring/loom for ease and better use.......
HELP!!
I am 90% sure you will need a turbo loom due to the knock sensors.
you may be better off looking for a power FC first and buying the correct loom for it.
it really depends on wich RB25DE head you are using 33 or 32.
if it was me I would buy a R32 re25de and use an R32 rb20det loom with an ap engineering pfc.
the loom and ECU will dictate wich CAS, ignighter and injectors you can run, once again in my opinion the r32 loom will be better as you can run top feed injectors.
Those of you with GTR's and or using GTR looms.
The knock sensors.
GTR
GTST
The GTR knock sensors don't screw in to the RB30 block as the thread dia of the GTR's bolt is too small.
What have you done/easiest way to sort the issue?
Brass piece chopped off and then drill/tap that brass piece to suit the GTR knock sensor bolt?
Or isn't there enough meat/difference in thread size to do such a thing?
i was goin to use a r33 rb25de engine for the conversion, tho im waying up weither to just buy a rb26dett head??
the only thing is price...
i was going to use the rb25de head with rb25det springs and maintain the vvt...
even though i get the de loom with the engine i will probably just hunt down a rb25det r33 loom or can i use the r32 rb20det loom???
cubes, i havent got to the knock sensores yet though what do u think would be the best approach as u have done it all....
thanks guys!!!
The knock sensors.
GTR
GTST
the bosses are there - on mine anyway - you just have to drill and tap them. the GTROC thread where R32 Combat / Andy shows his rebuild has good pics.
The knock sensors.
GTR
GTST
im not running them, simple lol (autronic SM4)
cheers champ.
Just a question before i buy it, am i able to use a rb25de NEO head??
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
