R33 Rb30 Conversion
lol the 2nd one boss, thank you for pointing this out. I feel as i spend more time here this intro message is some thing i will always make me laugh and shake my head at. Perfect Intro: I have the vehicle
R34DE as in R34 with an RB25DE? So did you get this? Or you planning to? I'm not really sure what you're saying.
Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
