GT-RZ i got the crank machined to suit my new rods and no its not nitrided i think the crank will be ok as its the same as the vl turbo one and wont be revving past 7 grand anyway so at the moment i have spent $5500
Complete RB30ET engine rebuilt kit
ACL MLS Headgasket 1mm
CP Forged 20 thou oversized flattop pistons to suit RB30DET build
Precision H-Beam Rods
Apexi Power FC
T3/T4 Turbo
Walbro fuel pump
Sard Fuel Pressure regulator
I need a few more things for it to be complete, balancing, injectors, head re-built, throttle body, plenum, clutch, flywheel, new engine mounts other ones are stuffed lol and thats all i can think of at the moment
do these types of things interchange?
I am going to try and run R32 RB25DE head with my R33 Power FC im guessing I need to change these sensors too? the coil packs will be fine wont they?
so far I have worked out i will also need to change some ecu pins around as the R32 had a different firing order
Pretty sure they are interchangable, my head came with a brown water temp sensor (which I believe is the same as RB25DET's), different resistance so the ecu ran in cold start all the time. Swapped it with a yellow sensor of an RB26 plenum (the old RB20 one that I snapped was yellow) and it works fine.
I wasn't aware that RB25DET's had a different firing order.. thought it was just reversed injector pinouts or something on the ecu..
Yours is s2 yeah? you'll need to keep your s2 coils if keeping the powerfc. If you were to change to a 20 ecu you'd need 20/26/25s1 coils to suit.
Have you considered injectors yet? 25DE plenum is practically identical to a 20DET plenum (slightly larger ports though) and as such run the same injector style as RB20's meaning your 25DET items won't bolt up.
IMO in a 33 you'd be better off using the 25DET head, for me in a 32 the 25DE was a major benefit as it all worked straight away and everything was in the same spot :huh:
My R33 is a S1 (94 model) have got S1 JJR Coils
Im going to go after-market Injectors anyway so I will just get top feed high impedance when I order em
I want to keep the R32 RB25DE head for a number of reasons:
Get to keep the RIPS Plenum
Dont have to pull apart a ready built motor
No VCT
So a set of SARD 550CC injectors for an RB25DET, won't fit an RB25DE from an R32 head?
hows it going guys another update on my setup. im trying to source a RB26 head to put onto my rb30. the reason because that i can sell my rb25 as a whole and get some money back.
i was wondering apart from rocker covers,centre cover,front cover,intake plenum,,idle control motor. would i be missing anything to run the motor?
ill be getting new cams so thats not a worry. i hear stuff about a wiring loom? do i need those?
sorry guys wen it comes to engines i know f*k all lol.
heard this term a lot and have limited my own 26/30 to 7k rpm with an ATI balancer BUT have yet to see or hear firm evidence of someone who has trashed an RB30 and can conclusively trace the cause to harmonics. not saying it an't so but can anyone provide evidence?
Scooby,
Harmonics will break a crank or could possibly cause early failure of the big end bearings after periods of sustained operation or extremely high load like in a drag or higher reving track car.
The main limitation of the RB30 with revs will not be a harmincs problem but an physical overload issue caused by the longer stroke and higher piston speeds of the RB30 bottom end.
How many people do you know who have actually broken a crank in a nissan? or any late model engine for that matter. much more likely you know ten who have thrown a rod out the side of a block!! generally this is due to a catastrophic failure due to overload I,E huge H.P or over reving, especially during a downchange through the gears.
Do some numbers on the difference in intertial loads and piston speeds with RB25/26 versus RB30 and you will quickly get the idea.
The end result of this is not a harmonics problem but a damn good reason to put a decent set of pistons and rods (read stronger) in if you want to rev it.
Anyway back to your original comment, I have built a RB30DET for a friend that has a 7000rpm limit (Rb25 harmonic balancer fitted) and is a daily driver. Considering that even if driven fairly hard it will only see the limiter a dozen or so times a week for short bursts there is no reason for it not to live a long and happily thrashed life. Harmonic problems in any stucture are only an issue when the frequncy remains CONSTANT! at a level which provides an amplitude which is detrimental to the structure, either continous or increasing due to it matching the natural resonance of the structure. This on a street car almost never happens as we are constantly changing gears and the engine speed changes with it. Also the engineers who design the crankshafts deliberatelly position the natural resonate frequency out of the normal operating range of the engine.
7000rpm and higher limiters for the RB30 are certainly not out of the question for a street driven engine, Just remeber what your driving when trying to decide how long to hold that third gear pull onto the freeway and you might want to lower it to be safe for track days if using more than 7000.
Dabro
No, RB25DET use side feed injectors and RB25DE from R32 use top feed
Possible to change whole fuel rail from the 25DET to the 25DE (R32 25DE that is)
Edit: No, it is not possible to do a direct swap. Found out today.
Edited by MBS206
I was after a RB25DE but now it looks as its easier to find a RB26 head for my 30 than an R32 Non VCT RB25DE. Whats the go with this and sensors/injectors etc etc. I have read the ENTIRE thread and am a little unsure.
To my knowledge i will need (providing i use a aftermarket comp etc e.g. PFC) all new sensors...or wat can i utilise from my rb20?
Any help will be greatly appreciated.
cheers, yeh i figured i would need the GTR injectors....anybody else know regarding the sensor side of things? what about AFM/Throttle bodies can i use a single one (read 32 AFM) or whats the go? am i better off biting the bullet and just getting a R32 RB25DE?
YOu can use any throttle body(single or multiple) any AFM, use the appropriate water temp sensor for the PFC, and use any early CAS(rb20.25 mitsubishi type,or 26) Use the appropriate O2 sensor for the PFC. You can use a single AFM on a RB26 PFC, but multiple AFM's on a rb25 PFC is a bit tricky. IMO the rb26 PFC is the way to go, as its far cheaper than the rest., although you may need to fit an injector resister pack if you have low impedence injectors.
Scooby,
Dabro
Some randomn things to add;
RB30E/RB30ET's were designed around a 6,250 rpm rev limit
Every 500 rpm increase in the rpm results in around a doubling of the force exerted on the crank, bearings, rods and pistons.
RB30's have a far superior rod length / stroke ratio than any other RB, this means less side force on the bores, rods and pistons.
This helps to ofset the often quoted higher piston speed argument
By far the most RB engine failures I have seen are due to oil control issues, then it's daylight, then some more daylight, then overheating.
If you rev an RB30DET/TT effeciently to 7,500 rpm thne you will be making over 750 bhp, so the first question you have to answer is "is my power target over 750 bhp". If it isn't, then why would you want to rev it to 7,500 rpm inefficiently, much smarter to simply change up a gear and take advantage of the faster acceleration.
The reason why I have an RB30 is so I DON'T have to rev it to make enough power, hence it lasts longer and costs less to build and to maintain.
Cheers
Gary
RB26's run low impedance (~3 ohm) injectors, RB20/25's run high impedance (~14 ohm) injectors.
Cheers
Gary
were they designed around a 6250 limit or is that the limit imposed on them due to longevity requirements, vehicle performance envelope etc and hence where holden put the redline on the tach?
i could probably second guess, but what's 'efficient' revving?
cheers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
