thanks for that. i'm aiming to get as much juice out of the 35r as possible so i guess it would be wise to go for mid 8's! wonder if CP make a piston for this ratio?
back to my origional plan but with lower comp! thank's allot.
ps: what is the max boost a 35r can run anyway?
EDIT: read up on it. max i'v read was 40psi. 35-38psi is safe for the turbo?
Edited by GT-RZ
I would assume that 35psi would be way outside the efficiency range for this turbo, for that sort of power i would be looking at an HKS T04Z, as they tend to have wheel trims suited to higher pressure ratios, but you would have to look at some compressor maps.
We make "special" swaybars, under the Selbys Swaybars brand name everyday for all sorts of applications. The HE sump into R32/33 is very common and I made a master (to copy) for them a couple of years ago. R33Racer's car runs one as well as my own R32GTST, plus quite a few more. I made one for Giant's GTR (that they used at Tsukuba) that clears the larger (Performance Metalcraft) sump as well as a dry sump pump. I also designed one for Mercury Motorsport for the RB25 into S13 conversion and we do Stewart Wilkin's and MadDats SR20DE and SR20DET into 1600 and 1200 swaybar conversions. Last week I finished a new design to clear a Trust sump on an SR20DET in a 1600.
So PM me, of course for SAU guys the prices are at Group Buy level and turn around is 2 days from order.
Cheers
Gary
Thanks Gary. :banana:
The PM was sent on the 2/2/08, just waiting on reply. If you haven't received it please let me know.
hmm yea. i don't know. i did a bit of reading but no flow charts. good example i found is below:
"Now observe the GT35R chart, HP holds steady and TQ falls alittle but not at the rate of the 50trim... GT35R chart was at 35 - 38 psi? Boost guage only goes upto 30...
When we were dynoing, the GT35R held HP/TQ at lower boost levels all the way to redline."
link to the page with the dyno results:
http://www.srtforums.com/forums/f169/gt35r...779/index3.html
i didn't read enough to see what engine it was running on though!?
You cant compare psi of boost to the power produced over different engines with different capacities and different breathing modifications.
Doing some math using the compressor map above the the turbo will be running out of its efficiency range after ~25 psi on the 3L, but that also depends on how well your engine breathes.
how that chart makes sense to you is beyond me! but thanks for the info. i think a to4z might be too laggy for what i want tbh. i read in one of the dyno examples a peak power of 470rwkw... i'm going to check that again because that's the kind of power i'm aiming for.
That would have had to be running some mega boost and top quality race fuel to achieve that power from a GT35R.
That's of course IF the dyno was accurate, which is probably unlikely :banana:.
Simple, the vertical scale is air pressure in bar, subtract 1 for boost and remember 1 bar = 14.7 psi
So 40 psi = 2.7 bar
Armed with that info, take a look at the graph and note that it doesn't go anywhere near 3.7 bar of air pressure (ie 2.7 bar of boost), in fact the efficiency island stop at 2.3 bar.
To run 40 psi, or anywhere near that, you are looking at using methanol or a dry ice intercooler, no petrol I know would tolerate such poor efficiency and no air to air intercooler I know of would cool it. Keep in mind that on average methanol would give you 10 to 15% more power than 100 ron petrol.
T04Z's with 0.8 turbine A/R's are far from laggy on a decent 3 litre, in fact many people would claim it a match made in heaven for the power/response compromise.
Cheers
Gary
Hey Guys,
I have read nearly all of this thread looking some detail on how to do the oil feed under the VCT solenoid and can only find out that you need to tap into the oil gallery. Does anyone have any photos? I have been running an RB30DET for nearly 2 years now and want to get the VCT running...Note that the oil gallery in bottom of head has been plugged...
Things I need to confirm are :
1. Where do you put the hole. ie vertical distance from solenoid + in from side or front of head...
2. What type / size of thread (1/8" BSP etc ) can you get in there?
3. Is it possible to do while the engine is in the car?? I suspect that you will need to remove the inlet manifold to get a drill in there.....
Once again I realise that there is heaps of info out there but i cant find any photos
cheers
I have just purchased a tial 38mm wastegate to use in my setup.
I currently have a brand new XR6 Turbo (GT3540IW - Housing: .5 front 1.06 rear) this will be sitting on a high mount manifold I was origonally going to block the external gate pipe of on the manifold and just run internal but as I got an awesome deal on the external gate I will run that up now.
Should I block off the internal gate completely?
Is it possible to run the two in conjunction with each other - I have heard some whispers about this a while back.
If i am best to block the internal what's the best way to go it without butchering the turbo as I may want to sell it down the track. I was thinking just capping it off by not running the split dump back into the exhaust / sticking a plate over the flange.
ahh, thanks for the info sydneykid, makes it a bit more clear now!
hmm i'm interested now because i know to4z means more power :( . what kind of compression would you suggest a to4z to run atand what boost would you guestimate would be safe!
thanks allot!
The guys that read my posts regularly know what's coming next............
Boost is irrelevant. Airflow makes horsepower, boost is simply a measure of the restrictions to that airflow. It is possible to make more power at lower boost levels, just remove the restrictions. A simplistic example, the T04Z is quite capable of 70 lbs/min of airlfow, enough for 800 bhp or so. It can do that sort of airflow from around 1.4 bar to 2.2 bar, but 2.2 bar will be outside the toptimum efficiency island. So the air will be hotter coming out of the turbo, hence you would need a much bigger intercooler, less ignition advance, richer A/F ratios, lower static compression ratio etc etc. That all leads to more lag, same horsepower. So why would you want to run 2.2 bar if it can make 800 bhp at 1.4 bar? The only reason you run more boost is because you haven't done a very good job in removing restrictions.
To answer your question, keeping the above in mind, I would run it at 9 to 1 compression ratio and around 1.5 bar.
Cheers
Gary
ah ok! so obviously because of the higher compression the boost does not have to be as high to produce the same output power. which gives the turbo an easier life because it doesn't need to work as hard (and supporting mods)?
thanks for your input. i'm decided now. to4z with 9-1 comp and i'll be using VVT also. should be a very responsive and powerful engine.
cheers.
Dan,
I have never ran two WGs but I would say definitely block the internal one if you can. If you run both WGs I think they may cause unstable boost control as they would open/close at different times. They may end up oscillating and causing unstable boost. An EBC wouldn't even be able to control them... If they were indetical WGs it may be a different story but external and internal gates have different fluid flow characteristics.
You also want to try and block off the internal one because in theory you would introduce lag by allowing the exhaust to leak or bypass the turbine all the time. One advantage of ext gates is that they dont leak when they are closed and by having a leaky internal gate (even if it is not activating) you would loose the advantage of the external gate. ie No leakage when closed...
I dont have any suggestions on how to block the internal gate though??? Can you get an ungated exhaust housing for that turbo??
You can have issues with ext. gates just as you can with int. gates.
A mates ext gate had nothing but troubles as its simply would not hold boost. Obviously influenced by its setup but none the less.
My int gate has no issues either does a correctly setup XR6T pushing 400rwkw out of its int gate.
RBman runs a XR6T turbo on his RB30DET; it makes from memory 1bar by ~3900rpm. No issues with boost control there. :)
Set it up correctly with thought and you shouldn't have issues with either. Don't bother wasting money if you don't have too.
Hey Guys,
cheers
drilling into an oil gallery is always going to introduce shavings, i would not do it with the head on the block for this reason.
TIP in the main area of the Forced Induction section - there is the Paper clip icon next to this threads link - click that icon and you will get a small page with EVERY pic that has been attached (not external links using the IMG tags though) to this thread - then go from there.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
