Finally fired the new machine into life with a slightly strange situation, Im running N1 pump, 26 head with 2 x 1mm restrictors. The strange part is I have fitted a mechanical autometer oil pressure gauge off the main gallery where the original RB30 oil pressure sender screw into & it gradually goes off the chart to 100psi at idle..... Im running 15/40 shell helix mineral oil, the std oil pressure gauge on the dash reads about 3/4. Not sure if I have an issue with the oil thickness or a bodgy gauge....
Anyone else had this?
I havnt fully warmed it up yet as still fitting the wideband sensor & want to make sure all is good
Cheers, Matt
I see 100psi at idle when cold (N1 pump), at normal operating temp. I see ~40psi at 2000rpm, ~60psi at 3000rpm, ~80psi at 4000rpm and 100psi after that. Hot idle sees 10-20psi depending on how hot the oil is.
Thanks, I warmed it right up last night & found pretty much the same result as yours, I was just a bit sus that I may have had something more sisnister causing it. Do you run a restrictor for your turbo oil feed? Im running GT3540 (brand new) & noticed a bit of oil in the compressor, I know they have small feed holes down in the cartridge but thinking I may need one in the block fitting similar to the standard banjo style or weather its just settling
come on strap that thing on i wanna see the response of it :P
lol
went to my mates workshop last night as he finally got the 26 back in the 32gtst that's in there. Took some measurements to see where the plenum sits in relation to strut tower etc. discovered I will need to get a 33 clutch master cylinder (which is good because mine just started leaking hehe).
Will be dropping the plenum off to be welded up later this week, once I get it back we can start bolting stuff on :O
Got a paintball tournament in 3 weeks and will be training a lot until then so it will be slow progress :O
Hi Guys,
just a quick question.
i have a R32 rb25de head with no cams and was thinking of getting the following:
2202-RN170, IN (256deg) (Lift 8.8) (valve timing 110)
2202-RN175, EX (264deg) (Lift 9.0) (valve timing 115)
what are your ideas on how these will go on a RB30/25 build
lol
Will be dropping the plenum off to be welded up later this week, once I get it back we can start bolting stuff on :D
Got a paintball tournament in 3 weeks and will be training a lot until then so it will be slow progress :P
I'm having the exact same issue with an aftermarket plenum.
if you can post some pics with the r33 one installed that would be great.
What head are those cams to suit?
the cams are for an RB20DET
i was wanting to get 264 in and out but the person i have been talk to can only do the below combo.
the other option i was thinking was Tomei Poncams 256 in and out with 8.5mm lift
Will do.
There is apparently some slight modification of the pushrod that needs to be made but my mate has done this before, I'll try document it for yas :D
If you have a look at your stocker one, imagine that the cylinder doesn't extend past the resevoir.. that's how big a 33 one is.
On another note, dropped my plenum bits off at the fabricator yesterday afternoon! :D
Will do.
On another note, dropped my plenum bits off at the fabricator yesterday afternoon! :(
I was also looking at aftermarket ones, i spoke to sydney race brakes who advised they should have something but for what price....
Another option is finding one from another make, alot of european cars have small cylinders with remote tanks.
Since my plenum is custom theres no rounded end so its the same heigh for the whole lenght.
Ill post pics when i get time.
$140 for a 33gtst clutch master cylinder. Shorten the pushrod slightly and bobs your aunty. I'm going to need to put mine in soon as I'm losing ~1/2 the resevoir in a little more than a day.
any opinions people?
Im putting a 26/30 into my r32 gtst. I am going to buy a new standard balancer to go with it. Does anyone know which one is the best to use? I am thinking rb26 but are all the belts the same. I dont have A/C anymore so that ones not an issue
cheers guys!
from memory it depends which power steering pump you are using, and if the belts line up correctly. Assuming the alternator/water pump belts are the same.
but for the price of the ross units why not just get one of them?
Edited by TiTAN
I read a few pages back that there are engine mounts that can be used to lower the motor a bit. Can someone please:
1) verify that this works?
2) confirm how much lowering we're talking about?
3) confirm where to get these engine mounts from?
Oh yeah, we started up the RB2630 the other day after a long arse build - thanks to everyone here who gave valuable info through PMs etc. So far we've made 330rwkw on 14psi through the auto gearbox. Torque was at 487nm, and it was at this point where the flex plate in the auto gave up (see pic below)
A new item has been sourced n sent down to MV Automatics for strengthening :bunny:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
