VCT question. Does anyone know where the hydraulic valve(ram) is on a R33det that controls the flow of oil to the camshaft phaser.
Need to know where to feed the oil to, as I believe I will be welding the vct oil gallery on the head
thanks
I must be a retard because I cant find what I am looking for even though I am sure its somwhere...
If I am going to put forged RB25 pistons (20 thou oversize) and eagle rods out of the same motor into an RB30 block, will comp ratio still be reasonable (8:1 or 8.5:1)? This combination will be fine I assume as in the .pdf its stated that bore is the same between 25/26/30. The rods are my concern but I am pretty sure they are interchangeable.
Sorry guys >_<
This is the wrong way to build the engine. The RB25 pistons have a lower compression height than the RB30 pistons, so they will be down the block about 0.5mm. The pistons have an 14cc dome on the top of them too. Assuming you deck the block to 0 thou you would have a cr of around 9.8:1, possibly higher if you have the head skimmed to make it dead flat.
Not machining the block to 0 thou deck would give you a little more chamber volume but this would also make the engine more prone to detonation as the sqush pads in the head are way too far away from the squish area on the pistons to make the combustion chamber efficent.
The ideal engine has a 0 deck height and a 0.040" (1mm) head gasket. Then set your desired CR using dished pistons after having your head cc'd. Using RB30 pistons gets you close to 8:1 depending on your head cc.
You should read the PDF file, it covers the options for piston choice.
how have people fixed their throttle cable issues. i have a q45 TB on a greddy plenum and using the stock throttle cable bracket i can hook up the cable but there is too much slack in the cable itself.
i heard you can get replacement disks that the throttle cable hooks onto on the throttle body so you can rotate it further to take up the slack. does anyone know where to get these? or am i better off getting the cable modified?
Edited by TiTAN
  • 3 weeks later...
car is running and has an initial tune on it.
Arias 9.2:1 comp pistons
Stock RB25 cams & springs with slightly cleaned up ports (completely stripped and rebuilt head)
VCT enabled
Greddy intake with Q45 TB
GT3582R 0.82 on an ETM manifold with 4" dump pipe, 50mm external wastegate
The engine is so much nicer off boost than the RB25 ever was and once its on boost the thing flys (making ~5psi by 2300 in 4th)
290kw @ the rear wheels 18 psi and bugger all ignition timing, 11:1 AFR up top and not making use of the WMI as something is leaking into the intake and fouling up the plugs/ deploying a smoke screen (to put it lightly) on the over run (PCV leaking oil, valve guide/s leaking oil, brake master cyl faulty and leaking fluid) any or all of the above. so we cant lean on it till thats fixed, should have an easy extra 70 or so kw left in it.
  • 4 weeks later...
does anyone know the nissan part number for the bolts that hold the crank girdle to the block?
i have asked Nissan but the say they can't find it in thier system.
what bolts do other people use?
thanks
I have the same TB with a CPC plenum where the rb20 and rb25 accel cables wouldnt reach. I found an Aussie R31 Rb30 cable that requires no mods to fit.
when i bougt mine 2 months ago
ATI917752 $1035 + GST/nil stock. (RB26, direct bolt on,-R32 for cars making 600-1000HP)
ATI917753 $1035 + GST/in stock. (RB26, direct bolt on,-R33-R34 for cars making 600-1000HP
form rocket industry's
Make sure the one your getting has serpentine belt drive unless it's a race car
But u can get them at perfomancewholesale.com.au for around 1000
cheers
can somebody tell me the difference between those 2 items.
just looking on the ATI website now, and they have an "r32 model" and the newer..
shouldnt be the same?
Not sure if this has been mentioned...
I recently got my RB25/30 running (last Tuesday). I did the mod for the VCT, however, all I did was grub screw the hole in the head, with no other modification. My VCT works perfect. No oil control/lack of oil issues or anything (this was mod was done on the advice of my engine builder).
Discuss.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
