Also remember people...
When you are quoted a price it ALWAYS ends up being more.
Its rather frustrating actually, as origionally I was quoted:
Head Reco: $415
Head work: $310
Total ------: $725.
I droped the head in and it ended up costing an initial of $830.
The head was in perfect nick no welding etc required.
Where the extra $100 came from I don't know.
After everything was assembled the total was/is $890.
Others quoted me $900 etc.. which is pretty close to $890 obviously, I wonder if they also would have jumped in price.
i just got quoted $495 + gst to have my head crack tested, surfaced, cleaned up, valves reseated and timing set up... then i have to supply the VRS kit on top of that price.
these guys will weld my vvt oil feed for free if i want them to, they also did a vac test on it and checked for warpage for free. It vaccums up alright and has very minimal (normal) degree or warpage. so thats all good news for the head :D
How about a whipple in the RB30DE engine I am looking at building an RB30DE with a supercharger instead and aim for over 250kW although I am more interested in a smooth torque curve so the power feels like n/a. Is this possible with say 5psi and about 9:1 comp ratio? I would retain the VVTi too...
well the engine and r33 gear box are in my 32, all that is left is one piece tailshaft, custom plenum, ta51/to4 turbo, custom in/ex manifolds, turbosmart 45mm wastegate, new dump, new intercooler, oil cooler with remote kit, 650cc injectors to bolt on.
hoping to race at Jamboree in a few weeks
Originally posted by Skyrine-Dave
Anyone know if i can just push top feed injectors into the RB25det fuel rail? like could i straight fit a top feed Rb20 injector straight in ?
Why use the Rb25DET fuel rail?? use the RB20 fuel rail.
Steve has recently performed this. Do a quick search.
It requires a simple modification with how the fuel rail bolts up. Apart from that they slide straight in.
I'm glad I am using the RB25DE head it makes things so much easier.
I currently have a R33 25T Skyline and am looking to do this conversion as well. Friend of mine is sending me up a rb30 short motor with the vvt oil outlet put in for me.. Also going to clean it up a little for me port the exhuast and intake ports a little. And move the Tensioner. From what I have read here I will be able to pull my motor out (with help from friends) and bolt on/hook up the rb30 bottom end to my Rb25DET top end. hook it all up - dial in some advance timing (25-27 degrees i belive i read that was what 25T is using) and drive away. :D happy boi :D as well as geting the gasket kits. From what I can tell the Rb25det injectors and oil pump will be fine with it all.
Joel your how to guide is awsome. Congrats to you on the job well done.
This is a extreamly helpfull thread!
its actually 4 to 6 degrees to get better low end torque, then when the rpm goes up the VVTi retard the cam in sync in order to keep the torque right up through the rev range. Up at a certain ammount of rmp the VVTi will stop retarding the cam at about 10 degrees at which point air speed falls behind the engine rpm speed. A turbo will increase torque at higher rpm due to the fact that at such high rpm it becomes inefficient for air to fill the cylinder before the valve closes. As air is forced in under higher then normal atmospheric pressure, the engines highest torque level will shift to a higher point in the rpm range.
say what???
Here's a quote from the post I thought we were talking about..
25T did the conversion and when on the dyno required this much timing. I think he made just over 200rwkw on 14psi and a stock ecu.
Ignition timing is different to cam timing.
Ignition timing is the spark fire timing at TDC.
It is what you set via the CAS, it sets the base ignition timing.
The ECU then adds or reduces timing depending on various variables i.e if you are running to much boost the R33 ecu will pull timing and richen up the fuel map in turn creating a power dip.
The CAS sets the base ignition timing for the ecu to work from.
Ok im in the process of reading all 25!!! pages (upto page 8)
Just like to clarify that Series 1 non turbo blocks, have blanks for the turbo fittings.
All series2 non turbo blocks (even some late 86 series 1 blocks) have bungs in place of the usual turbo fittings. You will have 3 fittings on the block, 1oil in, 1 oil drain (big bolt near the sump) and 1 water drain. The water feed comes off the heater hose fitting via a T peice from factory, peice of cake.
True turbo blocks are stamped with an A8 at the end of the engine number. Non turbo blocks (even with the bungs) are stamped A6 at the end of the engine number. The engine number is on the exhaust side, near the bell housing at the bottom.
Ill add some more comments when i get thorough it all. Pretty great info at the moment, but it needs to be all trimmed down to the relevent bits for the conversion, perhaps in a document or a modified version of the thread.
Question for the ppl using Arias pistons. If using std head gasket, and assuming any headwork doesnt bump up compression ratio, what CR do the forget Arias pistons leave you with.
Thanks
(Yes i did read the whole thread before asking question... now im taking an asprin and laying down... my head hurts)
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
