http://www.skylinesaustralia.com/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/
its way too easy to not do just for the sake of laziness. peak hp doesnt change at all without vct but you lose torque below 4500 rpm, something RB's need every bit of. for 5 mins of stuffing around its definately worth it
couldn't be bothered doing the extra work haha & you only lose acouple hp with out so i've been told...
got any links for the threads anyone?
hey people i'm doing this conversion my self & noticed on the rb25det there are an extra line from the head running to the block. what could these be used for? & what do i do with it as the rb30 block doesn't have a tapped hole on the block to fit it...
here's a pic of the rb25det block with the line>>
& here's the rb30 block that doesn't have a tapped hole to fit the line>>
If you have ever driven an rb25 without it you will know it is definitely worth keeping. Up to 10-15kw in the midrange on low throttle conditions.
alright i've worked out that line is the oil drain...
in that info guide it says (The Yellow highlight towards the rear of the block is the water return.
Water feed is provided from a hose/steel pipe assembly that feeds from the opposite side of the block) MY rb25 block has this blocked off do i run a water line from the other side somewhere?
  • 1 month later...
Hi everyone I'm slowly building up my 30 was wonderingwat computer will run a rb25/30 will a normal r33 apexi power fc work or do I need the pro version first time I've mucked around with computers thanks guys
it doesnt work without an oil feed. the solenoid simply feeds oil into a section of the cam which causes it to advance 20 degrees, no oil feed means no vct
Well mine does, and so do a few others I know of - has been checked by three workshops and an engine builder.
But I'm not going to argue with you about it (moreso the fact I don't fully understand why it is working, but it was the engine builder who did the modification without the feed knowing that it would still work).
Edited by cactus
There is a thread on how to supply the vct with oil internally instead of with an outside line:
  • 4 weeks later...
Can anyone tell me if there are any fouling issues with the RB30 sump into a R34. The guide says that with the 32's and 33's it's fine but nothing about 34's. I won't need to drop the engine any lower either as I'm not running the standard plenum.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
