just spoke to serco or as u call it wiseco they say if u use Forge pistons to suit na rb30 you need 2 mm head gasket to get 8.5-1 CR so i think the CR debate should be verified
this is using rb25de head this is what the guy said to suit this combo
not sure if this is correct
some of this info can be very confusing for an amature engine builder being a tradesman myself wrong information can lead to un desired results
if anyone can shed some light on this using wiseco NA forged pistons ie give a part number for an exact measured CR using the piston with correct head gasket would be very valuable info for this build up
Did you ask the guy why their catalogue looks to be so far out? It makes no sense, they have incorrect combustion chamber CC's, conrod lengths are inconsistent etc
Hi OVL-747, if the pipework is causing a restriction then it is too small.
sk - its not so much the i/d of the pipe , as its 2 ans 3/4 inch , but it has a conduluted plastic/rubber pipe , which is woefull on air flow.
thats why i have pissed all mine off in favour of nice stainless , with no afm either.
HKS 3037 ProS has internal wastegate..... looks stock.
GT30, GT35 need external wastegate. Very naughty! approx $2600 + $700 for w/g + $??? to modify manifold and w/g dump pipe.
Prices would come out close, depending on the duties imposed on the 3037.
Nothing naughty about external wastegates at all.
And like GiJOr33 said.. if you are going for such a turbo why not take advantage of it and use an custom manifold.. for the record garret GT35's can be had for $2000, brand spanking new. *looks at GT35R :D *
no - too big for a 'normal' rb25
Nothing stock looking about a 3037PROS
Skyrine Dave - the whole garrett vs HKS thing has been discussed in depth in a monstor thread, so if you want several opinions, try a search:)
Yeah not too big... but i think a 2835R turbo would be a damn good match for an RB25. Big enough to give good flow and power, and small enough so that boost comes on early enough to use it on the street. The 3040 turbo's are good too... better for slight modded RB25's like forged pistons as you can then run some higher boost and get some good power out of it.
I don't know what the HKS 2835R or HKS 3040 would compare to in the Garret range (even though the HKS turbos are based on Garret) as i dont know too much about garret turbo's!
Where?
I didn't think external gates were 'road legal'. Or is that just if it has a screamer pipe?
For those of you who have purchased a turbo from Greenline, how much did it cost all up? Just wondering what duties, taxes and shipping costs applied.
Anyone??
I well know the difference and facts :D, i was more questioning why you would want an HKS turbo for almost twice the price and less potential
i too think intergates on larger turbos are a waste of time... if you aer going for a large HP flow tubo, use an external gate.
Monsta: external venting wastegates (ie screamer pipe) are illegal. But external wastegates that are plumbed back into the exhaust are perfecly fine and legal *in most sates that arent overly nazi on mods
Hi All
Fantastic thread......
I am considering creating one of these frankensteins for my R31 Skyline Sedan.
So most of it should be fairly straight forward.
1. Has anyone used an auto? What power levels can the Auto delivered in Aus
Series 3 Skylines handle (the 4 speed Electronic). What about the RB25DE Auto.
(p.s. Yes I can drive a manual thanks very much) :wassup:
2. Cruise control, throttle cable. I can see that the throttle cable goes directly from the drivers side of the engine bay, on the R31 it loops around and comes
in from the passenger side, I have factory cruise control that comes in from the
passenger side also. Has anyone seen a R32 half cut with the cruise control solenoid and linkage on the throttle body.
3. Looms, I am going to use a R32 RB25DE Loom prob from a half cut, do the engine sensor>ECU part of the loom seperate reasonably easily from the rest of
the loom.
4. Insurance, as my car is currently NA I will have to let the insurance company
know that it will be turbo, (pretty obvious if they do an inspection). What
insurance companies are good with this sort of thing.
5. Turbo, the factory RB25DET Turbo may not last if you increase the boost too
much, what about other Import Turbos, say from a Supra or something, is there
something that will bolt on to a RB25DET exhaust manifold and offer a benefit.
I am only looking for arounf 200-240rwkw
Sorry for all the questions, but this is the most knowledge that I have seen in the
one place for a long time.
:( Maxy
behind a half decent rb30DET, i would give the aus series 3 auto prehaps 10minutes of life.
if you want an auto, either jatco (vl, vl-t, series 1&2 r31) and get it rebuilt and strengthened, or get a trimatic and also get it strengthened.
no idea about the later model auto's.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
