has anyone seen or used a mechanical fuel pump such as this one.
How 2,500 horses get fed.
Capable of supporting 350 to 2,500 hp, these fuel pumps are made just for serious racers. They flow 2,700 lbs./hr. of fuel, deliver 2 to 200 psi worth of fuel pressure, and work with any type of fuel. That's enough fuel flow and pressure to support a 6-second drag car--fuel injected, blown, turbocharged, or otherwise! Their belt-driven design means there's no current draw, and the pumps require no priming. They have a billet aluminum housing and bracket, a -10 AN O-ring port, and an anodized finish.
https://www.sau.com.au/forums/topic/155020-mechanical-fuel-pump/
You will need a fuel tank in the engine bay no more than 500mm from the pump, it will need to be at least 10 litres you will still need an electric pump this can be a low psi unit used primarily to fill the engine bay tank. I wouldnt suggest running it off the camshaft like GIbson, you will probably snap it, it will need to run off the crank, and you will need to work out the pulley sizes and make a custom one for your balancer. the pulley size is crucial to make sure you have enough pressure on idle... another factor will be the car will be difficult to start as when you are winding it over you arent generating much pressure so you may need a little pressure resevior with a stop valve that will work on start up.
Your $600 pump will easily run you $2000 buy the time everything is set up properly.. Not exagerating.
Edited by Fitzpatrick Speed Works
You will need a fuel tank in the engine bay no more than 500mm from the pump, it will need to be at least 10 litres you will still need an electric pump this can be a low psi unit used primarily to fill the engine bay tank. I wouldnt suggest running it off the camshaft like GIbson, you will probably snap it, it will need to run off the crank, and you will need to work out the pulley sizes and make a custom one for your balancer. the pulley size is crucial to make sure you have enough pressure on idle... another factor will be the car will be difficult to start as when you are winding it over you arent generating much pressure so you may need a little pressure resevior with a stop valve that work on start up.
Your $600 pump will easily run you $2000 buy the time everything is set up froperly.. Not exagerating.
if it is run off the crank, would there be a sizable/noticeable power loss due to the extra load?
No i wouldnt say so, maybe 5-10rwkw max at full noise, much the same as a AC compressor, your car may feel a little sluggish compared to what your used to though again the same as when the AC is on.
Why would it snap a cam shaft ? Its a ribbed belt so it doesnt need to be super tight. Surely compressing a valve spring would have more resistance than this pump. And if it was good enough for the Gibson GTR it will do me.
http://www.skylinesaustralia.com/forums/in...howtopic=121344
I would not think a mechanical pump would take anymore energy to drive at the same flow / pressure than a electric pump, both are gear pumps. But i guess there would be a little more parasitic losses caused fiction on the belt drive. But then again you still have a belt drive to your alternator which supplies your electric fuel pump and voltage drop as well to the fuel pump in the rear of the car.
Edited by tacker
Yeah Gibson had billet cams, and if it snapped on a gibson GTR what did they have that you dont, SPARE motors and an basically unlimited budget.
If you own a street car you are being ridiculous if you run a mech pump, mechanical pumps are nothing new to me have used them for a very long time on blown alcohol V8's they are good things but they aren't street friendly, or cheap to set up, that $600 pump will blow out.
Another note theres a thread running at the moment on snapped camshafts, these thing are as fragile as glass I have snapped one myself just tightning the bearing, a pump no matter the belt type is resistance. I simply would never feel safe running it off the camshafts. Reece Mcgregor runs his of the crank, you could almost argue if its good enough for Reece its good enough for me. But then again both the Gibson car and Reece's are out and out race cars at the very highest level.
Oh and another thing the Gibson ran the pump as a secondary measure look in the boot there is still an intense electric fuel syste, in place...as you said if its good enough for Gibson.....!!!
I asked the same question to the owner of the ex-gibson GTSR which runs the same system.
He basically told me that all the fancy pumps in the boot feed the mech pump and that the elec pumps couldnt hold a candle to the capability of the mech pump.
The reason, as someone already mentioned was that they used injectors that were too small (he told me they were standard?) to flow the fuel requirements being fed from only electric pumps so the mech one was there to force the fuel through the injectors no doubt with a tad bit of fuel pressure.
What do you mean the mechanical pump was a second measure? as other have said it was needed to increase the pressure to run through stock injector.
Also are HKS cams billet items as i am only knew to skylines and i dont want my glass camshafts to break
I too have talked to the guy with the r31 race cars with mech pumps, and as stated the mech pump was to increase the pressure from the electric ones,the mech pump was not used as a sole operating pump. Thus it was a second measure, thats what I mean.
You also stated price as a factor, as I have stated you will not do a mech fuel system cheaper than 2x044 and a surge tank.
At the end of the day do what you like, you asked if anyone has seen or used a pump like this so I answered your thread, cause i have both seen the pump you are referring to as I actually own one that is being mounted to a FJ20, and I have used similar pumps and had lengthy discussions with the heat treatments team about drag racing fuel systems set-ups. That being said, if you have no use for the info I am offering and from what I can tell just being a smart arse back who it seems has made up their mind stop asking questions that you don't like the answers to.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
