got r32 gtst
haveing isues with it feeling squirmy in the rear any idears
changed shocks
got hicas lock bar
got new rack ends cause they were stuffed as well
then i changed subframe bushes to noltec ones
then got tein flex coilovers cause the ilets on the bottom of my tunable were f**ked
and it still feels like hard core 4 weel steer coming out of corners and big launches
any idears
i was thinking maybee teh camber arms and traction arms
or maybee bushes in lower controll arms
theres nothing else to replace
also maybee weel bearings
reason for this topic is 1 i want to get it sorted
2 does anyone done rear arms on a 32 and know what fits over the teins
i hade a mate with s15 and same flex coilovers brought whiteline rear arms and they didint fit so any help with this much appricatied
ps sorr for all the spelling and grama errors
thanks guys
https://www.sau.com.au/forums/topic/155170-r32-rear-arms/
well I'm not really sure what is causing the play you are getting in the rear suspension. I'm just about to fit some cusco rear upper arms so I think they will fit over Teins or anything like that. I'm also putting in some ikeya formula traction rods. so I guess that answers part of your question. I'm quite sure the cusco arms work fine with japanese coil-over kits.
https://www.sau.com.au/forums/topic/155170-r32-rear-arms/#findComment-2886745
I've had the same problem in the past and found that by replacing everything it fixed the problem. If you replace everything your should eliminate the problem aswell >_< About all you have left to do is the bushes anyway.
Project D upper arms cleared both my cuscos and teins. They are modelled on cuscos so i assume a cusco one will fit too. I haven't heard of anyone having problems with fitting any of the jap (or copy)adjustable upper arms.
Anyway, enough banging on. What height do you have your car set at and what are the alignment settings on the rear end (camber and toe). What tyres are on there?
https://www.sau.com.au/forums/topic/155170-r32-rear-arms/#findComment-2887046
Looks to me like you haven't done the tie rod ends for the HICAS bar, or maybe the ball joints at the hub end of the tie rods, we had trouble with them....caused toe to move by something like 1cm at times....it was terrible tor drive
https://www.sau.com.au/forums/topic/155170-r32-rear-arms/#findComment-2887428
u mean rack ends as i replaceed them these are the things that screw into the hicas rack right
as for tyres yokahama v102
18* 8 235/40/18
um camber about 2.5 deg max adjust
and to to suit tp prevent tyre where
think maybee need to do drives side weel bearing
did passanger about a year ago
https://www.sau.com.au/forums/topic/155170-r32-rear-arms/#findComment-2888591
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
