BP is the only refinery in WA anyway, so technically it'll still be BP.
Usually other Brands put there own magic additives in the blend...
but otherwise it'll mean 98 will be easier to get in those situations where you would normally have to hunt for a BP... i think everyone here has had that experience at least once.
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2888871
ok... who here every time they fill up on bp ultimate put a bottle of octane booster in as well? ive heard that the fuel in japan is 101 octane and that with our fuel we should put in a bottle of octane booster aswell
that would probably make your fuel 98.1 octane and give your plugs a beautiful orange colour
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890148
Dan, there actually some good octane boosters out there. Besides orange is pretty.
Can anyone CONFIRM where Peak get their 98 octane from. Is it in fact BP or is it from Singapore?
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890485
Well this is great news. The only reason I went to BP was because they were the only ones who had it, now that peak and caltex do i'll be able to shop around. Sure i'll probably only save a few cents each time I fill up, but it's more about the principal :laugh: (and the fact that I hate BP because they are always more expensive and bump up their prices randomly with no valid justification for doing so except to rip people off)
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890902
Well they all change their prices randomly. BP is no different.
Anyway why do you hate them so much. Just think where we would all be if BP didn't sell 98 Octane?
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2890932
Just been on the phone to Peak. They often source their finsihed product from Singapore, but the chemist said their 98 is sourced from a Mobil refinery and is the same spec as the Utimate. I assume Caltex is sourced from one of their east coast refineries but I have not been able to confirm this.
Forgein ayyy! Good info skylion.
Should be cheaper but wont be as they colude to keep prices artificially high. Depending on what, if anything, is used to boost the octane rating, toluene (methylbenzene or phenylmethane) or ethanol it is reasonable to expect your tune up to change. I would be very careful with trying different fuel, check your AFR's and be prepared to make the changes. Hp gains have been made by Skyliners on the East Coast using Ethanol boosted fuels. Caveat emptor
Nicking fuel from the airport LOL mmmmm JetA1
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2891618
imagine running jet avo fuel and having a bee*r limiter!!! = massive flames
pop, pop, pop, KERBANG, wooooooooooooooooooooosh!!!!!!!!!!!!
wouldn't adding ethanol and/or toulene be a good thing for your car as it burns better and cleaner?
if it is i can see how ur tune would change anyway
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2891921
keep it on topic please. there have been plenty if toulene threads before which has covered all of this.
https://www.sau.com.au/forums/topic/155318-98ron-at-peak/#findComment-2892058
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
