  • Replies 41
STD RB26
EMANAGE ULTIMATE PLUG AND PLAY WITH OPTIONAL PRESSURE SENSOR
700CC BLITZ INJECTORS
TRUST T517Z'S TURBO'S WITH 8CM HOUSINGS (BABY'S)
TRUST INTAKE AND COOLER PIPING KIT
TRUST COOLER
JJR ALLOY PIPE KIT
STD DUMPS
TRUST MILD STEEL FRONT PIPES
TRUST 80MM TITANIUM CAT-OUT EXHAUST
290.8RWKW @ 14.8PSI
328RWKW @ 18PSI
yeah they didnt arrive in time, i only like the to use these as they offer the best results with the combo.
we also stopped at 18psi as the car will only run 15psi during comp use.
Even so doing the runs @18psi with 3 people in the boot and a few differrent attempts to stop wheel spin we could not get a wheelspin free run..... damn those drifted on square tyres realistically i would expect a bit more say 15rwkw at 18psi and 10rwkw @ 15psi but it will have to wait. I really wanted to tune up to 22psi as these things really come on song up there but having a flashy dyno sheet was not worth the effort of changing tyres.... call me lazy.
PICS SOON
Edited by URAS
yeah what a dissapointing weekend at round two of DA for DCR, we had issues with the car all weekend.... somewhere in the 10yo factory GTR loom is an evil power robbing wiring gremlin.... car would not rev over 5000rpm consistantly.... bring on the next round.
i was suprised she qualified mid field with such a misbehaving car .....
What exhaust components did you customise (if any)?
I'd assume you would leave the front pipe sitting in such a way that any off-the-shelf S13 catback would fit.
None GTR front pipes and s13 cat back line up perfectly
trent hows the car going mate? was spuen the tailshaft let go on the dyno, cant believe the damage and it was so close to you aswell.. The dyno is fixed :blink: all is a.o.k down there, next time your on dyno i must see!!!
You guys heading down to winton tomorow with it?
  • 4 weeks later...
UPDATE:
Had the car a Calder for its first real shakedown and after lots of suspension fettling the car seems to be quite a weapon. looking forward to having some fun at wakefield on the weekend.
Edited by URAS
BTW nice looking car looks mint on the track.
I notice the power figures you quote are quite nice but @ calder it seemed to bog down a lot, fuel up and struggle to go anywhere. I know a lot of GT-R guys ditched the trust turbo's due to lag are you guys have some issues or just not finished tuning?
not sure what you mean? she could not find enough grip she was harldy ever giving it much stick ie hardly reved it over 6000 as it spun str8 to redline.... it is actually too responsive (better than the garret 2860-5's used on previous cars). and could not get traction..... maybe it looked that way as we were not drifting the last corner properly as the car holds too much speed to pull up in time for the barriers, the final corner is a no brainer and wastes tyres for no reason......
we also dont go to these practice nights at calder to go flat out comp style, we go there just to set up the car a lot of people mistake testing different aspects of the car to us actaully having problems, we had only a few handling issues (lack of traction) which is now sorted.
The car is going to NSW for a comp this weekend and we could not afford to damage so we only did what we needed not what people probaly wanted to see..... which opens a whole other issue, i dont think people should have to pay to watch a practice session because many expect to go and see drifting only. Often we will only do one section at a time make a few changes and try another section purely to save the car and tyres..... and the crowd doesnt understand this (obvious from your statement) other drivers even put in complaints that we were doing fishies on the str8 and when they themselves did it they got kicked off...... we were warming tyres....big differrence.
Edited by URAS
  • 3 weeks later...
hey trent will you and cat be at winton on the 23rd? if so, hope to see you guys there :D
The r33 is finished and is at creatd to get tuned, hopefully it goes well also being my first time on track ;)
cheers. Phill
  • 4 weeks later...
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
