  • Replies 44
Posted Images
T04FTR ---- in terms of the response, its pretty responsive compare to my RB20 with GT3040R. with my GT3040R in my RB20DEt i was getting full boost at 4600rpm but ut was pretty slugish. BUT with my new setup boost kicks in at 5600RPM but i can feel it pulling before it hits full boost.
i took the car to WSID in november last year just to test it out how it goes with street tires, i tried it at 16 psi ( my max boost setting) and the car was going sideways all the way in 4th gear ( from 2nd gear i put my foot down) and i finished the 400m in nutural :) that day i manged 13.0 @ 116 mph at 10psi.
Also as i mentioned befor my Exhaust housing size is 1.16 which is pretty big compare to ordinary T04Zs. Coz my turbo has been customly built for my application.
Its pretty pointless to darg withought my Mickies.
Cheers :huh:
cooool thats just what i wanted to know. thanks mate :)
  • 3 weeks later...
  • 5 months later...
does a fully rebuilt/balanced rb25/30 Neo have the power band to do these turbos justice? Im interested in the ones slides sell with a 1.01 a/r? I would think max rpm would be 7500rpm. Would i have any clearance issues aswell?
cheers
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
