  • Replies 44
Posted Images
T04FTR ---- in terms of the response, its pretty responsive compare to my RB20 with GT3040R. with my GT3040R in my RB20DEt i was getting full boost at 4600rpm but ut was pretty slugish. BUT with my new setup boost kicks in at 5600RPM but i can feel it pulling before it hits full boost.
i took the car to WSID in november last year just to test it out how it goes with street tires, i tried it at 16 psi ( my max boost setting) and the car was going sideways all the way in 4th gear ( from 2nd gear i put my foot down) and i finished the 400m in nutural :) that day i manged 13.0 @ 116 mph at 10psi.
Also as i mentioned befor my Exhaust housing size is 1.16 which is pretty big compare to ordinary T04Zs. Coz my turbo has been customly built for my application.
Its pretty pointless to darg withought my Mickies.
Cheers :huh:
cooool thats just what i wanted to know. thanks mate :)
  • 3 weeks later...
  • 5 months later...
does a fully rebuilt/balanced rb25/30 Neo have the power band to do these turbos justice? Im interested in the ones slides sell with a 1.01 a/r? I would think max rpm would be 7500rpm. Would i have any clearance issues aswell?
cheers
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
