  • Replies 43
Popular Days
Dude leading a pack of skylines on a cruise, hits second gear and starts to drift sideways out of a corner, then backs off when the back of the car starts to overtake the front. They slide all the way 180 degrees and end up facing the wrong way in the scrub on the opposite side of the road. You see all the skylines behind him overtake. Then he takes off and floors it overtaking everyone to make it to the front of the pack again.. The passenger meanwhile is telling him to slow down cos he doesnt want to die today!
you guys have zero clue!
the passager (the person filming) and the driver are very good friends!
get over urselfs!
Its nice to see everyone jump onto the bangwangon, like you all havn't driven like dickheads at one stage or another in your car
also note: im not saying his action where right, or wrong....
He shouldnt be trying something new in front of other peoples most prized possestions, just imagine if he coutersteered to much and rammed another car.
who said he was tring something new in front of other people?
Why is that the only opinion?
Could it be possible he was still getting uses to his new power level and losts it, That he wasnt tring to be a heroe but just gave it alittle too much around the turn ?!?
Im sure some of you have spun out on a cruise or just driving around... im sure that some of you werent tring to be drifters but just gave it that little too much... :happy:
Im also sure that if another drivers on the cruise had a problem with his driving they would have gone upto the driver and told him and the driver would have appoligised... and im sure he adjusted his driving after that event
AGAIN IM NOT TRING TO SAY HIS ACTION WHERE OK! im just saying there are many opinions to why/what/when happened etc etc
' date='10 Feb 2007, 03:43 PM' post='2896090']
so how do you explain the other clip with him dragging the other skyline?
not really.... ill only give it a squirt if there's no one around
Maybe no one had a problem with that? maybe everyone was keen to see a gts-t and gtr run? Maybe the 2 owners knew each another and wanted to see how there cars would go :happy:
Maybe the drag happen before the spin out :happy:
who knows :? i wasnt on the cruise
Maybe people should stop blowing their money on mods for power and start going to a few track and skid pan days instead. If you're not used to the power of a car you don't blindly abuse it by mashing the pedal from first to second on a 90 degree corner, pretty simple really.
I've got nothing against people giving their cars a bootfull but only when I know the driver can actually control the car, this guy clearly couldn't. You'd think that after an incident like that he would tame his driving a bit but as seen on the video, he continues driving like a dick, retards like this just don't learn and give the rest of us a bad name.
either way it shouldnt have happened, he didnt do by accident.
yes ive done some stupid shit before, but never on a busy road, espically with a set of cars right behind me.
and, if i did something stupid in front of everyone id back off take it easy for the reat of the cruise instead of overtaking everyone and trying to get to the front.
steve
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
