Wondering if anyone knows if this is normal, I've tested the voltage outputs from my CAS and have found something that may be a problem.
The signal from the 1degree output is around 2.4 volts and sits quite steady at idle. But the 120degree signal seems very erratic, jumping between 0.9 to 1.6volts at idle.
Is this normal, or is my CAS U/S?
https://www.sau.com.au/forums/topic/155957-crank-angle-sensor/
Well with a bit of research I found the CAS test section in the stagea service manual
It says the 120 degree signal should be between 1.3v to 1.4v at idle, and I imagine it should be a reasonably steady reading aswell.
So it's looking as though mine is playing up.
Please sit down before reading this part.
A new item is worth $1042 from Nissan, what a joke that is.
Oh if anyone is kind enough, maybe they could test the voltage on their CAS so I can compare with mine.
I can supply ECU pin numbers, wire colours etc if needed.
I wanna know 100% for sure.
Let's just hope mine isn't playing up as well. I've been getting quite bad fuel consumption lately, and I've yet to pinpoint the problem due to my g/f's car being out of action. I'll let you know when she won't be using the car and you can go around and pull mine apart :laugh:
Cheers mate, only have to get to the ecu plug, to take a voltage reading.
DATS interesting Brendan. Now my shoulder is getting better I am going to try and solve my P. poor fuel consumption, so this could be an area to check.
It is quite interesting, I'm finding, I've realised it's much easier to find a problem with the right gear and a full service manual.
Talking about the right gear, i'm lucky enough to be able to borrow the ocilliscope from work, so I'll diagnose this sucker once and for all.
Ok, I've tested the output with the ocilliscope, and it looks fine compared to the service manual. Back to the drawing board.
One thing I noticed yesterday before I started it the voltage from the MAF was 0.9 volts, manual says 0.2 volts.
Didn't test it until after it was started today, and the voltage looked fine. Will have to test again tomorrow before startup.
This is really getting annoying.
Wont need to now, thanks for the offer though mate, much appreciated.
Working afternoon shift aswell, till 11pm, so wouldn't be able to make it.
I'm reasonably satisfied that the CAS is ok now, I'm looking at the MAF sensor now, will hopefully have an answer tomorrow.
I've been searching the forum, and it seems as though the issue i'm having is very common. And no one seems to have a definate answer.
So I'll keep prodding away, and will hopefully find something.
The CAS produces a pulsing signal when the engine is running, the 1 degree is stable because it is more frequent, hence the multimeter reading doesn't vary much. The 120 degree signal is less frequent hence the multimeter reading does vary.
As far as I know you can't check CAS operation with a multimeter at idle. The 120 degree signal should stabilse as the rpm rises. So maybe try it at higher rpm, that's where you should/might get the Nissan manual voltages.
;) Cheers :sleep:
hmm I had a CAS fail years ago on my r33, it was a real pain to track down, one of the most intermittent missfires I've ever seen.
Ended up paying around 400 for a second hand one - I almost had a heart attack at the nissan price....
Do you have a consult cable? You can get a reading off most of your sensors and make sure they are acting OK while you are driving
  • 1 month later...
guys and gals
didnt want to create a new thread to ask the question .. so found some talk of consult ports in here
can anyone send me / describe the consult port on a 2000 Stagea?
I have a consult cable that I used on my old pulsar and wondering if the pin outs etc are the same?
I have calumsult and nissan datascan etc. IT would be great if the consult cable can be used on the stagea too.
( ps I dont actually HAVE the car yet hence why I cant just try it out. Thanks guys.
Edited by ssshonky
guys and gals
my 99 s1 (late model) stagea has a 14pin consult connector
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
