Suspension Workshop/info Night At Heasmans - Bilstein In Sydney
  • Replies 154
Hi gtr fan. SAU NSW membership is $35 per year, and a once off $25 joining fee (includes $10 worth of SAU sticker). It's well worth the money, and as we are a cams affiliated club you can use your SAU membership for your CAMS licence application. Plus there are many other benefits. More info in here:
http://www.skylinesaustralia.com/forums/in...showtopic=44115
Jordan, this is perfect for anyone with an interest in improving the handling of their car, and learning a bit about suspension. even with no prior knowledge of suspension systems you will get plenty out of this evening. BUT at this point it's open only to SAU NSW financial members (see above). If we do not get enough attendees we may allow any forum members to attend, but I would suggest joining the SAU NSW club anyway. There are lots of good reasons. :huh:
UPDATE:
The dates has been confirmed with Bilstein.
Tuesday 24th April starting at 7pm (arrive between 6:30 and 7:00pm if possible). It is expected to finish before 10pm
I can also confirm this will involve a tour of all their good gear including the shock dyno room and mobile shock centre (race truck). There will also be a special guest coming. He has lots of experience in race car preperation and set-up and is a fountain of information on suspension set-up, particularly with skylines. So I would say this is an even not to be missed!
good to see! Well we are at 19. My target for this is 20-30 SAU NSW members. Learning a bit about suspension from these guys should not be underated. and the "special guest" is worth coming to see too.
adam you big girl. man up and just get your crack wax another day. a week of stuble never killed anyone.
well, we now have 20 people on this so it's looking to be a good night. 10 more spots to fill. Don't be shy, get your name in here.
PLEASE RE-CHECK THE FIRST POST. DUE TO SCHEDULE PROBLEMS HEASMANS HAVE ADVISED ME WE NEED TO CHANGE THE DATE TO TUESDAY 24th.
sorry guys. nothing I could do about this change, but I hope it wont be a problem for most of you.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
