Who Has Had Their Car Tuned By Advan Performance?
I have a HR34 GT... RB20DE My speedo doesn't work! The rest of the gauges seem to work, fuel and RPM. I did not notice if my odometer was going up when driving last. Any ideas? Speed sensor? Hopefully atleast... Gauge cluster perhaps? Or is that unlikely because the other gauges are working? Any insight is appreciated. This is a rather new to me car. Lol
I'm guessing you mean something like this size? https://www.supercheapauto.com.au/p/bodyworx-bodyworx-hard-soft-sanding-block---70-x-135mm/594184.html?cgid=SCA01100303#srsltid=AfmBOoq_qZTEe3boann9BaHiB2f59dxJlosWLzCr0zm_weHgUlDX-N5f&start=6 Are they sanded completely flat? -
Just a standard sanding block size. With the rock chipa they are quite small. I sanded them as you could feel the edges.
Say you've just laid all your filler and your about to start sanding, how large is the sanding block your using? Like a high fill primer? Technically possible but would be a nightmare. Just guessing from the photo, but they look small enough that you might get away with using a 1k spot putty. Normally you'd use something like this on pinholes but with the type of project you're working on I'd give it a go.
