  • Replies 508
i dont think it ever will be. it wont meet any sevs criteria. unless you could argue it's shape as a unique design feature, and then get HPI to run a feature article on it. then it would satisfy sevs to get put on the list. BUT then you still need a RAW to apply for compliance for it. atm your only hope is move to japan for a year. buy one. then bring it back. or just go for a holiday in japan and rent one.
edit: I've been in one a couple of times now. :happy:
I agree that the Cube will almost certainly never be allowed because it fails to meet the minimum power to weight ratio required for the SEVS scheme, that means it would have to have some sort of outstanding design features which is doesn't appear to have, so it would almost certainly be rejected if an application was to be submitted.
minimum power to weight ratio?
lol I think he wanted to know why that was a restriction Baron.
For a vehicle like the Cube to be considered for addition to the SEVS register (the list of the cars that could possibly be imported under SEVS), it must satisfy at least two of the following criteria: Appearance, Unusual Design Features, Performance, and Featured in specialist motoring magazines in factory condition..
Under the performance category, one of the requirements is a power to weight ratio greater 105 kw/tonne.
What J-Spec and Baron are trying to get at is that it could be featured in a magazine, but it would most likely not meet the appearance or unusual design features tests and hence be ineligible.
I'm working on the Toyota bB at the moment, using the appearance criteria. One aspect of it is silhouette, and I think it should qualify fairly well, as would the Cube.
Will see how we go with the bB first.
i like the green ones with an army type look. wink if you want one bad enough send me some cash and ill look after it for you for a year :D
Haha. Let me look at some prices on the auctions. :)
You need one of these. Daihatsu Naked. They look worse in the flesh, and they are K.
I have to say they don't even look half as good as the Cube.
saw a dark blue in Adelaide. Would love to buy a Bb open deck if they are available
  • 1 year later...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
