  • Replies 70
Depends on alot of factors like your power/torque curve peak power point, post up your dyno graph so we can analyse it.
Here's my graph... I'm no expert but it does look like I could gain a few tenths by not shifting so high :)
Ye, but a VL weight is a lot less, and they are using Autos.
Two key factors that does change things quite a bit
Vl turbo weight alot less, how much do they weigh..maybe 50kgs lighter????
And using autos, that was the whole point of the thread in the way they were set-up I was refering to running 10's mate with 300rwkw+..it was off topic to r33god though just stating some points from what 700hpGTR said.
please read carefully...
Thank you..
Edited by MZTRBO
Thank you..
i forgive you for talkin about 300+ rwk lol... 12's soon to come by me :(
thanks for the inputs though peoples... keep it comin
cheers
Thank you..
Go check the weight of an SL Berlina vs an R33.
You'll find its a fair bit more than 50kg's if you do some research.
Go check the numbers for yourself if you think im wrong.
I grew up around VL's, and only the Calais come close to the weight of an R33 :(
I grew up around VL's, and only the Calais come close to the weight of an R33 :wave:
As i was refering to a vl turbo and most of them being calais's here is some info for you...
Calais
Base Turbo V8
1354 1383 1407
Thats 1383kgs, last time I checked r33's didnt weigh more then 1400kgs??? Oh by the way I own a r33 gtst and I recently sold a vl sl berlina so thats why I was pretty confident in the weighting department..thank you thank you..
Even if it was a berlina turbo its about 50kgs lighter if that, like I previously stated...
I look forward to your prompt response..I rest my case
Sorry R33GOD no more from me...
Good Luck and have fun...
Cheers
Calais
Base Turbo V8
1354 1383 1407
Cheers
The drags are comin soon enough. 33 will be ready in 2 weeks :wave: thanks for the info.
much appreciated :wave:
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
