  • Replies 70
Depends on alot of factors like your power/torque curve peak power point, post up your dyno graph so we can analyse it.
Here's my graph... I'm no expert but it does look like I could gain a few tenths by not shifting so high :)
Ye, but a VL weight is a lot less, and they are using Autos.
Two key factors that does change things quite a bit
Vl turbo weight alot less, how much do they weigh..maybe 50kgs lighter????
And using autos, that was the whole point of the thread in the way they were set-up I was refering to running 10's mate with 300rwkw+..it was off topic to r33god though just stating some points from what 700hpGTR said.
please read carefully...
Thank you..
Edited by MZTRBO
Thank you..
i forgive you for talkin about 300+ rwk lol... 12's soon to come by me :(
thanks for the inputs though peoples... keep it comin
cheers
Thank you..
Go check the weight of an SL Berlina vs an R33.
You'll find its a fair bit more than 50kg's if you do some research.
Go check the numbers for yourself if you think im wrong.
I grew up around VL's, and only the Calais come close to the weight of an R33 :(
I grew up around VL's, and only the Calais come close to the weight of an R33 :wave:
As i was refering to a vl turbo and most of them being calais's here is some info for you...
Calais
Base Turbo V8
1354 1383 1407
Thats 1383kgs, last time I checked r33's didnt weigh more then 1400kgs??? Oh by the way I own a r33 gtst and I recently sold a vl sl berlina so thats why I was pretty confident in the weighting department..thank you thank you..
Even if it was a berlina turbo its about 50kgs lighter if that, like I previously stated...
I look forward to your prompt response..I rest my case
Sorry R33GOD no more from me...
Good Luck and have fun...
Cheers
Calais
Base Turbo V8
1354 1383 1407
Cheers
The drags are comin soon enough. 33 will be ready in 2 weeks :wave: thanks for the info.
much appreciated :wave:
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
