The best ones are the genuine Nissan items.
I have a set...2...supplied to me at $25each ...Did not use them cause the mechanic said they would not last.
Ring up Nissan...or get a mechanic to buy them for you...this is the cheapest way.
Hope I have been of some help.
https://www.sau.com.au/forums/topic/157253-turbo-gaskets/#findComment-2920406
Honestly, with gaskets, go genuine nissan. If you don't, you'll be banging your head against a brick wall thinking why did I save those few bucks.
Many $$ later, or many skinned knuckles later, you will have done the job twice when it should have been done right the first time.
Those aftermarket gaskets are shit. They're thin foil with some goo sandwitched between. They can be blown out and don't last.
the genuine nissan gaskets are a solid metal like copper or something.
https://www.sau.com.au/forums/topic/157253-turbo-gaskets/#findComment-2920615
  • 3 months later...
umm. kk.
best way to do it is not touch the water lines on the turbos. just the pipe fittings at the rear.big bango in the middle and the oil/water bangos on the comp cover brackets.
and loosen all the ones on the block. the front and rear turbos come off the manifolds at the same time. ps.. nice good quality open end stubby spanners is needed.
should take 4-5 hours iff all gos to plan drive in/out
https://www.sau.com.au/forums/topic/157253-turbo-gaskets/#findComment-3182126
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
