Hay guys,
As you know we are building a S.A.U BBQ trailer and we need your input.
We have already are the main parts like:
6x4 trailer
2x BBQ (to be cut up and used for there parts)
Two Skyline wheels (supplied by ASH)
Some of the ideas that have been throne about are the boot of a skyline would be cool as an icebox or a storage area?
Cannon Exhausts to stick out the back to make it look good?
All right guys we need you input please post up what ideas you have and what you can donate and we will have the best-looking BBQ trailer out there (It will look much cooler then the WRX trailer)
  • Replies 102
Posted Images
this was dicussed at last nights meeting
we are getting an official sau vic bbq trailer
but we want to mod it up a little for some fun
so like skyline rear taillgihts on it, r33 wheels on it
any other stuff anyone can donate thats cheap / free for fun
i can donate
stock boost solenoid
powerfc hand contrller (dead)
ebay poor mans spec oil pressure guage
1 x GTR32 stock turbo front compressor cover and wheel also
So we're going to make silly suggestions, treat this thread as a joke and nothing gets done OR are we actually going to have some valuable input? :laugh:
Not too sure what i can donate as such, need to check the shed, but my time is always available :) .
A rear half cut from a damaged skyline would be utter cool. *cough* Dave *cough* :laugh:. Even if it is slightly damaged someone will be able to straighten it up, to make it look presentable; the pannel beating doesn't need to be anywhere near "show" standard, but this would look awesome on our stand at various major events!
so who's actually going to do all the work ?
why dont u start with just a frame, and build a complete custom trailer, you could design it so much better ... :laugh:
The genious :)
Work done by various members, hopefully mostly donated.
I can probably do most the wiring. I have done heaps of car installs in the past, etc.
i can make like an official slump glass sign of "SAU BBQ! EAT IT OR GTFO!"
or just SAUBBQ in glass :laugh:
lol :)
Not sure if glass is a good idea... unless you reckon you can get something that wont destroy itself?
The genious :)
i beleive they said they already had a 6x4 trailer ... it would be a much better and viable option to sell of the trailer and buy materials, as, if you make the actual chasis of the trailer to suit the exterior design it will flow alot easier ???
dang, didnt take a pic of the last trailer i worked on :laugh:
i could help although various tools help i cant bring a mig welder from work ... i dont thik they will let me:(
lol :)
if i had a toughening plant, then i could supply that. but we always get it from other joints.
although i do like the idea of a big sticker saying "SAU BBQ! EAT IT OR GTFO!" on the guards or something
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
